I have a pretty simple setup. I have about 7 devices being controlled; 5 lights and an aquarium in my home theater area. I used to control these devices using x10 with a ir-543 IR to X10 controller, a harmony remote, indigo and a 1132u.
I have made the move to Insteon with the platnium package from fun for geeks.
everything seems to be working. I no longer use the harmony remote setup and instead put the controLinc on the end table. I configured Indigo to list all my devices including the controLinc V2. Instead of "linking" the x10 and/or Insteon devices to the controLinc I created triggers in Indigo so when Indigo recieves a command from the controLinc it then sends the command to the device. This has proven to be a bit slow at times. Currently all 5 lamps are X10 with 5 LampLinc Insteons arriving on Tuesday of this week.
the reason i set it up this way i so Indigo knows the status of the lamps at all times. The only way to turn them on and off is through Indigo this way. The other reason is because the aquarium On and Off actually do a group action and I have a movie mode which turns multiple lights off in order.
So, my questions are
When i get the insteon lamplincs do i "link" them to the controlinc?
If i do that will indigo know their status?
Do i leave the triggers in place with the link or just use one or the other?
Does status update automatically in indigo with insteon devices?
any ideas, suggestions and any other help is appreciated. I have been reading everything i can get my hands on and have been setting all this up for days. Maybe i just need a day or two break from it....
