The only way I can think of controlling an Insteon device from a PalmPad remote is to make a trigger action for each command needed. Deselecting the mapping in the receiver setup is also necessary. Is this the best way?
Also, my first instinct when setting up the Insteon device was to look for an device option that did something like "Respond to this X10 address", where you would then select an X10 address. Seems like a logical feature since most home will probably still use X10 controllers for quite a while. X10 devices could benefit from an option to "Respond to these Insteon commands".
Kyle
Disclamer: I didn't give these ideas much thought. I am not to be held responsible if they are stupid.[/i]
