DPattee wrote:Did you go with all battery-powered ones or some hardwired ones? If battery-only, how are you finding the life?
Most of my rooms have the standard 3-wire 120v alarm wiring but thanks to First Alert's product line it seems that I have to pick either CO monitoring or long battery life (120v), but not both!
matt (support) wrote:dshj wrote:midd wrote:What exactly is the local ramp rate duration setting? It's set to half a second in the setting but I don't know what it's for.
I think this is a carry-over from the LampLinc that this unit is basically built in. The Smoke Bridge is clearly a re-worked LampLinc.
I just improved (for the next beta of Indigo 6) how Indigo handles the Smoke Bridge. It will no longer show the LampLinc UI. It will have an ON/OFF state (like a door/window or motion sensor) that will go to ON when the Smoke Bridge detects Smoke (group 1), Carbon Monoxide (group 2), or Test Mode (group 3) and will go to OFF when the Smoke Bridge sends the All Alerts Clear (group 5).
So you'll be able to create a Device State change trigger to catch if there is an important alert (smoke or carbon monoxide). At this point you'll still need individual INSTEON Received Triggers for the other messages (like battery low).
Once beta 8 of Indigo 6 is released re-sync your Smoke Bridge device to update how Indigo shows/handles the device.
