I've been looking for something like this for a long time. Anyone know if it's the real thing and will work as advertised?
http://www.smarthome.com/2982-222/INSTE ... =HML13RA18
matt (support) wrote:The current beta of Indigo 6 has preliminary support for the INSTEON FirstAlert Bridge, so that you can create Triggers to catch the alerts it sends. I only have an older early beta of the bridge myself, so we cannot commit that Indigo is totally compatible with what will be the shipping version of the bridge. But in theory it should work.
midd wrote:What exactly is the local ramp rate duration setting? It's set to half a second in the setting but I don't know what it's for.
midd wrote:Secondly, know how to set it up for sending a message and what not. But I would want indigo to send it after 20 seconds of the alarm actually going off, not necessarily 20 seconds after the SB reports reports it to indigo. The reason being is that if my batteries start dying, the alarms will activate for a few seconds then shut off. I would like to avoid getting a message for that reason. Wouldn't want to cause a panic to me or the wife if we get message saying the house is burning down when in fact it's only the batteries.
dshj wrote:midd wrote:What exactly is the local ramp rate duration setting? It's set to half a second in the setting but I don't know what it's for.
I think this is a carry-over from the LampLink that this unit is basically built in. The Smoke Bridge is clearly a re-worked LampLink.midd wrote:Secondly, know how to set it up for sending a message and what not. But I would want indigo to send it after 20 seconds of the alarm actually going off, not necessarily 20 seconds after the SB reports reports it to indigo. The reason being is that if my batteries start dying, the alarms will activate for a few seconds then shut off. I would like to avoid getting a message for that reason. Wouldn't want to cause a panic to me or the wife if we get message saying the house is burning down when in fact it's only the batteries.
I think you would want to set your triggers based on the message that comes to the Smoke Bridge. A "low battery" alert (group 6) is different from a "smoke detected" alert (group 1).
What are you having Insteon do after it receives a message from the Smoke Bridge? What group are you triggering from?
I think this is a carry-over from the LampLinc that this unit is basically built in. The Smoke Bridge is clearly a re-worked LampLinc.
matt (support) wrote:dshj wrote:midd wrote:What exactly is the local ramp rate duration setting? It's set to half a second in the setting but I don't know what it's for.
I just improved (for the next beta of Indigo 6) how Indigo handles the Smoke Bridge. It will no longer show the LampLinc UI. It will have an ON/OFF state (like a door/window or motion sensor) that will go to ON when the Smoke Bridge detects Smoke (group 1), Carbon Monoxide (group 2), or Test Mode (group 3) and will go to OFF when the Smoke Bridge sends the All Alerts Clear (group 5).
So you'll be able to create a Device State change trigger to catch if there is an important alert (smoke or carbon monoxide). At this point you'll still need individual INSTEON Received Triggers for the other messages (like battery low).
Once beta 8 of Indigo 6 is released re-sync your Smoke Bridge device to update how Indigo shows/handles the device.
