I have a ToggleLinc in my closet that was linked to a Trigger Link that was broken. So can't unlink the Togglelink and I'm trying to reset it to Factory Defaults. The following is from the manuals. I've tried this several ways and it doesn't work. My questions are when you pull out the set button do you hold it out for 10 seconds?? Then it says to push the set button down. Does this mean push the set button in? I've done this and it never beeps so I don't think I'm doing something correct. It's a Togglelink Version 2 Firmware Version 38. Is this older and needs to be reset differently?
Resetting ToggleLinc to its Factory Default Settings
The factory reset procedure can be used to clear the ToggleLinc memory and restore its factory default settings. This procedure will clear the unit of all INSTEON Links and any programmed X10 address.
Before resetting a ToggleLinc that has been Linked to an INSTEON Controller, be sure to Unlink it from the Controller first. See Unlinking ToggleLinc from an INSTEON Controller.
If you are using ToggleLinc to control any INSTEON devices other than the light it is wired to, Unlink those devices from ToggleLinc. See Unlinking a Controlled INSTEON Device from ToggleLinc.
Gently pull the Set button at the bottom of the switch out as far as it will go (about 1/8 inch). This "air gap" removes all power to ToggleLinc
The Status LED and the load will turn off
After 10 seconds, push the Set button all the way down and hold until the unit beeps
A few seconds after you release the Set button, the unit will double-beep and the Status LED and load will turn on
