Insteon IRLinc Receiver 2411R...ABOUT TIME!
Sun Mar 09, 2008 3:35 pm
dacostad offline
(No subject)
That is correct Matt, that is exactly what I did.
David
Sat Apr 19, 2008 8:42 pm
Alain offline
(No subject)
[quote="dacostad"]Here is my proceedure.
5. Press the "Send PowerLinc set button pressed" button on the IRLinc device you set up in Indigo and the light on the IRLinc should go back to faint steady light.
I'm using Indigo 2 and I'm trying to set up my IRLink. For some reason, I don't see a "Send PowerLinc set button pressed" button on the IRLinc edit window.
Is this still a button available in the most recent version?
Alain
Sun Apr 20, 2008 9:03 am
(No subject)
Hi Alain,
That button will be visible inside the Device's edit dialog (double click on the device name in the Main Window), once you have defined and sync'd it to a IR-Linc.
Regards,
Matt
