Insteon 2843-222 Open/Close Sensor (Inverse Operation?)
Sat May 08, 2021 10:50 am
SearchCz offline
I have an odd application for a 2843-222 Open/Close sensor where it would be helpful if I can get this thing to send the opposite commands. That is, I would like to get an OFF command when the door open, and an ON command when it closes. Maybe there is a raw command I can send that will accomplish this? Any ideas?
Fri May 14, 2021 12:26 pm
Re: Insteon 2843-222 Open/Close Sensor (Inverse Operation?)
Take a look at the Device Extensions 3rd party plugin here. In particular, I believe you can use this to create a new device that has the opposite boolean state.
Sat May 15, 2021 2:36 pm
SearchCz offline
I'll check it out! I might hang an NC micro switch off that 2843-222 to gain an OPEN status when door is closed.
Users browsing this forum: No registered users and 21 guests
