Insteon Linked Dimmer for 3-way Circuit ERROR CODE & STATUS
Wed May 05, 2021 1:08 pm
ukie offline
Just installed 4 2477D Dimmers for hallway and stairs, both 3-way circuits. Firmware 45.
The secondary dimmers have been linked to the primary dimmers using Insteon's manual instructions (not Indigo).
So in Indigo I only add the two primary dimmers.
While the setup works as expected, in terms of controlling the lights manually, the ON/OFF status is not updated in Indigo when controlling the lights from the secondary dimmer.
This is the case with both circuits.
Indigo gives the following error:
 Received INSTEON                "Stairs" on
   Group Trigger Error             no address to name data found for received command:ackValue : 0
address : 58.35.9B
cmdBytes : [17, 0]
cmdFunc : on
cmdScene : 1
cmdSuccess : True
cmdValue : 0
replyBytes : []
   Group Trigger Error             Error in plugin execution ReceivedBroadcast:
  File "plugin.py", line 500, in insteonCommandReceived
UnboundLocalError: local variable 'cmdDev' referenced before assignment
   Received INSTEON                58.3F.0D off (button 1)
address : 58.3F.0D
cmdBytes : [19, 0]
cmdFunc : off
cmdScene : 1
cmdSuccess : True
cmdValue : None
replyBytes : []
Wed May 05, 2021 1:43 pm
Re: Insteon Linked Dimmer for 3-way Circuit ERROR CODE & STA
That error is from the Group Trigger 3rd party plugin, not from Indigo. It has nothing to do with the status updates.
Read over this wiki article that describes multi-way circuits with Insteon - it discusses the issue you see and how to deal with it. It probably doesn't help that the intra-device links were created outside of Indigo, but assuming you've synced them all since doing the manual links I don't believe that's an issue.
Thu May 06, 2021 7:34 pm
ukie offline
That helps. Thank you.
Users browsing this forum: Google [Bot] and 9 guests
