Insteon KeypadLinc – Button 7 Off Comman not working
Wed Sep 30, 2020 4:13 pm
Venicenerd offline
Hey guys,
I have had this system up and running for about a year without any issues and all of a sudden I'm having an issue with my KeyPad Linc. I have it set up that if you press (turn on) keypad button #7 it will turn on a virtual device in Indigo. If you press it again (turn off) it will turn off a virtual device in Indigo. This has been working perfectly for a year and when the button is in the "off" state a press still turns it on and the virtual device turns on as well. However, once the button is in the "on"state pressing the button won't turn it off anymore. The button just flashes twice and then returns to the " on " state and hence the virtual device isn't tuned off either.
I really don't understand what happened. The button is just supposed to turn on and off and press which turns on and off a virtual device.
Anyone know how I can fix this? Nothing has changed on my software side at all. I didn't make any changes.
Any help would be greatly appreciated!
Wed Sep 30, 2020 4:39 pm
Re: Insteon KeypadLinc – Button 7 Off Comman not working
The double flash generally means that it can't reach a responder (presumably the PowerLinc). Resync the KPL in Indigo and see if that repairs the missing links.
Wed Sep 30, 2020 4:46 pm
Venicenerd offline
Hi Jay,
Thanks for the quick reply. Weird though that it only doesn’t work for the off press, right? Could you quickly walk me through on how I should resync the KPL? Don’t wanna do anything wrong! ;)
Philipp
Wed Sep 30, 2020 5:06 pm
Open the device config dialog and press the Define and Sync button... ;)
Thu Apr 22, 2021 2:36 pm
Venicenerd offline
Hey Jay,
so sorry for the late response. I was stuck in Europe due to COVID and was just now able to travel back and have a look at the problem in person. I used the Define & Sync button as you had suggested but, unfortunately, it didn't do the trick. Let me give you some more details of the issue.
I have two Insteon Switches in my home that turn on/off this virtual device. Switch 303.S1 (living room) and Switch 306.S2 (bedroom). Everything works as expected on switch 306.S2. Here is a screenshot of the Insteon device links:
And here is a quick video of the working button in action:
https://www.dropbox.com/s/m2cx8gtcef1ue ... 9.mov?dl=0
And then we have Switch 303.S1 in the living room where the virtual device can only be turned on but not off:
not working.jpg (210.52 KiB) Viewed 1792 times
And a video (I'm also showing the Skylights virtual device button in this video which works as expected. It's just the Blinds button that does not):
https://www.dropbox.com/s/s86i6z85do0y1 ... 9.mov?dl=0
Do you have any additional trouble shooting steps I could take? I have no idea why this stopped working.
Thanks so much!
Philipp
Fri Apr 23, 2021 1:56 pm
Hi Philipp,
We need to see the Event Log results of the device sync as well as both buttons being toggles (both working and failure cases), so open the Event Log window then re-define/sync the module (via the device dialog for the KeypadLinc), then toggle both buttons a few times and copy/paste the Event Log window results into a reply for us.
Sat Apr 24, 2021 6:15 pm
Venicenerd offline
Hi Matt,
thanks so much for looking into this for me! Here is the log:
Apr 24, 2021 at 5:09:58 PM
PowerLinc Linking - entered discovery linking mode (240 seconds)
PowerLinc Linking - syncing PowerLinc links (address 49.F8.80)
PowerLinc Linking - . . adding: INSTEON plc link to controller 4F.5D.9E, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . adding: (not added -- probably already exists)
PowerLinc Linking - PowerLinc links updated
PowerLinc Linking - sync complete
PowerLinc Linking - sending engine version request to 4F.5D.9E
PowerLinc Linking - received engine version 02 from 4F.5D.9E
PowerLinc Linking - sending id request for device information to 4F.5D.9E
PowerLinc Linking - received id request response from 4F.5D.9E
PowerLinc Linking - initializing remote device "303.S1" (address 4F.5D.9E, firmware version 45)
PowerLinc Linking - . reading: configuration settings
PowerLinc Linking - . . . read: configuration settings 0C, keypad in 8 button mode
PowerLinc Linking - . . . read: backlight brightness 100%
PowerLinc Linking - . . . read: default on brightness 80%, ramp rate duration 8.5 seconds
PowerLinc Linking - initialize complete
PowerLinc Linking - syncing remote device "303.S1" (address 4F.5D.9E, firmware version 45)
PowerLinc Linking - device "303.S1" properties updated
PowerLinc Linking - syncing all links
PowerLinc Linking - . . . read: INSTEON dev link to controller 49.F8.80, flags AA, group FE, data 00 1C 00
PowerLinc Linking - . . . read: INSTEON dev link to responder 49.F8.80, flags E2, group 01, data 03 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to responder 49.F8.80, flags E2, group 02, data 03 1F 02
PowerLinc Linking - . . . read: INSTEON dev link to responder 49.F8.80, flags E2, group 03, data 03 1F 03
PowerLinc Linking - . . . read: INSTEON dev link to responder 49.F8.80, flags EA, group 04, data 03 1F 04
PowerLinc Linking - . . . read: INSTEON dev link to responder 49.F8.80, flags EA, group 05, data 03 1F 05
PowerLinc Linking - . . . read: INSTEON dev link to responder 49.F8.80, flags EA, group 06, data 03 1F 06
PowerLinc Linking - . . . read: INSTEON dev link to responder 49.F8.80, flags EA, group 07, data 03 1F 07
PowerLinc Linking - . . . read: INSTEON dev link to responder 49.F8.80, flags EA, group 08, data 03 1F 08
PowerLinc Linking - . . . read: INSTEON dev link to controller 51.72.62, flags A2, group 03, data 8C 1C 01
PowerLinc Linking - . . . read: INSTEON dev link to responder 51.72.62, flags E2, group 06, data 03 1F 06
PowerLinc Linking - . . . read: INSTEON dev link to responder 4E.67.49, flags E2, group 02, data 03 1F 02
PowerLinc Linking - . . . read: INSTEON dev link to responder 4E.65.60, flags E2, group 03, data 03 1F 03
PowerLinc Linking - . . . read: INSTEON dev link to responder 43.65.8B, flags E2, group 04, data 03 1F 04
PowerLinc Linking - . . . read: INSTEON dev link to responder 4F.61.34, flags E2, group 05, data 03 1F 05
PowerLinc Linking - . . . read: INSTEON dev link to controller 4F.61.34, flags A2, group 05, data CC 1C 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 43.65.8B, flags A2, group 05, data CC 1C 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 49.F8.80, flags A2, group 0A, data FF 1F 02
PowerLinc Linking - . . . read: INSTEON dev link to controller 49.F8.80, flags A2, group 0C, data FF 1F 04
PowerLinc Linking - . . . read: INSTEON dev link to controller 49.F8.80, flags A2, group 0D, data FF 1F 03
PowerLinc Linking - . . . read: INSTEON dev link to controller 49.F8.80, flags A2, group 0E, data FF 1F 05
PowerLinc Linking - . . . read: INSTEON dev link to controller 49.F8.80, flags A2, group 0F, data FF 1F 06
PowerLinc Linking - . . . read: INSTEON dev link to controller 49.F8.80, flags A2, group 17, data FF 1F 07
PowerLinc Linking - . . . read: INSTEON dev link to controller 49.F8.80, flags A2, group 18, data FF 1F 08
PowerLinc Linking - . . found: PowerLinc responder for group 1
PowerLinc Linking - . . found: PowerLinc responder for group 2
PowerLinc Linking - . . found: PowerLinc responder for group 3
PowerLinc Linking - . . found: PowerLinc responder for group 4
PowerLinc Linking - . . found: PowerLinc responder for group 5
PowerLinc Linking - . . found: PowerLinc responder for group 6
PowerLinc Linking - . . found: PowerLinc responder for group 7
PowerLinc Linking - . . found: PowerLinc responder for group 8
PowerLinc Linking - comparing local and remote links
PowerLinc Linking - . mismatch: remote link differs from persistent link 51.72.62, flags A2, group 03 (changing remote link)
PowerLinc Linking - . . match: remote link is identical to persistent link 51.72.62, flags E2, group 06
PowerLinc Linking - . . match: remote link is identical to persistent link 4E.67.49, flags E2, group 02
PowerLinc Linking - . . match: remote link is identical to persistent link 4E.65.60, flags E2, group 03
PowerLinc Linking - . . match: remote link is identical to persistent link 43.65.8B, flags E2, group 04
PowerLinc Linking - . . match: remote link is identical to persistent link 4F.61.34, flags E2, group 05
PowerLinc Linking - . . match: remote link is identical to persistent link 4F.61.34, flags A2, group 05
PowerLinc Linking - . . match: remote link is identical to persistent link 43.65.8B, flags A2, group 05
PowerLinc Linking - . . match: remote link is identical to persistent link 49.F8.80, flags A2, group 0A
PowerLinc Linking - . . match: remote link is identical to persistent link 49.F8.80, flags A2, group 0C
PowerLinc Linking - . . match: remote link is identical to persistent link 49.F8.80, flags A2, group 0D
PowerLinc Linking - . . match: remote link is identical to persistent link 49.F8.80, flags A2, group 0E
PowerLinc Linking - . . match: remote link is identical to persistent link 49.F8.80, flags A2, group 0F
PowerLinc Linking - . . match: remote link is identical to persistent link 49.F8.80, flags A2, group 17
PowerLinc Linking - . . match: remote link is identical to persistent link 49.F8.80, flags A2, group 18
PowerLinc Linking - compare complete
PowerLinc Linking - . changing: INSTEON dev link to controller 51.72.62, flags A2, group 03, data 8C 1C 01
PowerLinc Linking - . . . . to: INSTEON dev link to controller 51.72.62, flags A2, group 03, data CC 1C 01
PowerLinc Linking - device "303.S1" links updated
PowerLinc Linking - exited linking mode
Sent INSTEON "303.S1" status request (received: 0)
Sent INSTEON "303.S1" keypad button states request (received: 0, 0, 0, 0, 0, 0, 0, 0)
Received INSTEON "303.S1" on (button 7)
Trigger Turn On Blinds 303.S1
Action Group Blinds ON
Virtual Devices sent "Blinds" on
Trigger Blinds ON (button change)
Sent INSTEON "PowerLinc Interface" on to 100% (instant) (scene 23 - Blinds)
Received INSTEON "303.S1" on (button 8)
Trigger Turn On Skylights 303.S1
Action Group Skylights ON
Virtual Devices sent "Skylights" on
Trigger Skylights ON (button change)
Schedule Skylights ON (button change) (delayed action)
Sent INSTEON "PowerLinc Interface" on to 100% (instant) (scene 24 - Skylights)
Received INSTEON "303.S1" off (button 8)
Trigger Turn Off Skylights 303.S1
Action Group Skylights OFF
Virtual Devices sent "Skylights" off
Trigger Skylights OFF (button change)
Sent INSTEON "PowerLinc Interface" off (instant) (scene 24 - Skylights)
Apr 24, 2021 at 5:11:58 PM
Received INSTEON "306.S2" on (button 5)
Trigger Turn ON Blinds 306.S2
Received INSTEON "306.S2" off (button 5)
Trigger Turn OFF Blinds 306.S2
Action Group Blinds OFF
Virtual Devices sent "Blinds" off
Trigger Blinds OFF (button change)
Sent INSTEON "PowerLinc Interface" off (instant) (scene 23 - Blinds)
I pressed the Blinds Off Button on 303.S1 after I pressed the blinds On button. But it seems it doesn't even register in the log. The Skylights button on 303.S1 works fine. And the Skylights AND blind buttons on 306.S2 work fine as well.
Please let me know if you need me to send you any other info.
Philipp
Sun Apr 25, 2021 3:07 pm
The sync is showing that there are links for every button on 303.S1 back to the PowerLinc, so each button press should be sending an Insteon command for the PowerLinc (and thus Indigo) to receive.
If you are consistently seeing button presses for some buttons on the 303.S1 in the Event Log but not others (blinds off in this case?), then I think the module has started to malfunction and should be replaced. You can try factory resetting the module (per its instructions) and re-syncing it in Indigo to see if that helps, but if it doesn't and the problem is specific to that button only (and thus not a general Insteon signal/noise issue) then I think it probably needs to be replaced.
Sun Apr 25, 2021 4:44 pm
Venicenerd offline
I factory reset the switch and synced it again and that actually fixed the issue!!! Thanks so much. So glad this works again! :)
