rbdubz3 wrote:Oh - forgot to mention - the new (AZ Warehouse) FanLinc came with the wires 'out of order' with what is shown in the installation pdf manual from Insteon - Instead of White->Black->Red->Blue it was White->Blue->Red->Black .. Go figure.. I decided to trust that 'black' was 'black' and not really blue - it seems to work ok except for the non-whisper quiet issues with LOW/MED ... Nice quality control Insteon!!!
Don't expect any two FanLinc's to act the same if they are from different REVISION's. SmartLabs is always making changes, sometimes the units function better - but I have also seen a newer REVISION be much worse.
I have two identical fans side by side with different REV FanLincs and they don't act the same. They even spin at slightly different speeds.
It would be helpful for you to post the REV and DATECODE for the unit that failed and the new one installed. Also the Fan make/model.
TIP: Tired of seeing the FanLinc LED's glowing from inside your fan's cover plate? This will turn them off.Interfaces > Insteon/X10 Powerline > Execute Raw Insteon Command
Select Device from list
Command 1 Byte 0x20
Command 2 Byte 0x08 [turns them OFF] 0x09 [turns them ON]
Check "send extended message"
D1 to D14 Bytes 0x00
Save it to an Action Group so you are ready the next time you need to change the LED's
