Strange PowerLink and MacMini behavior with power outages
Thu Feb 20, 2020 12:54 am
AlaskaDave offline
Living in Alaska Power outages is a common event. I have a UPS attached to my MacMini and have the Mac set to "Start up automatically after a power failure". When I have a power failure the MacMini never automatically starts up and when I do restart by selecting it's power button and Indigo restarts I have to unplug and plug back in my 2413U PowerLink Modem. If I don't it shows up in red and crossed out in my home screen. What gives? For the MacMini to restart is there another setting that I'm missing? And why would I need to plug back in my Modem?
Thanks for any advice.
Thu Feb 20, 2020 7:31 am
Re: Strange PowerLink and MacMini behavior with power outage
If you have a Mac on a UPS, what's shutting it down? Is the a serial/USB connection to the UPS that's commanding shutdown? As I understand it, a UPS commanded shutdown is not considered a "power failure", so the automatic restart doesn't happen.
What do you have the Shutdown Options set to in System Preferences?
Only solution I know of is to get a bigger UPS so that it never needs to shut down.
Fri Feb 21, 2020 11:41 am
jltnol offline
And FYI, although I don't have the UPS/Restart issue, I DO have the PowerLInc not being recognized whenever I restart the computer. Like you, I just unplug, and replug it, and its good to go. This seems to be a driver problem where the OS will load the wrong driver at startup, but load the right one once its unplugged.
See this thread:
https://forums.indigodomo.com/viewtopic.php?f=7&t=23380
Fri Feb 21, 2020 11:52 am
AlaskaDave offline
Good to know about the driver issue, will read the link provided. As for my UPS, turns out my battery is toast. I am usually not around for power outages so I simulated one by unplugging from the wall. Battery lasted about 5 seconds with only the MacMini installed and running.
Fri Feb 21, 2020 11:53 am
Yeah, that's pretty dead.
