Keypadlinc deleting a device
Sat Nov 23, 2019 12:36 pm
rweil1 offline
Hello,
Just wondering if anyone sees this under the links menu in the KPL device. I had an erratic din-rail device that just would'nt dim LED lights properly. I replaced it with a switchlinc dimmer which seems to dim LED's just fine. I deleted the device but the remnants of the old device still appear inside the menu. "not editable".
I did the factory reset but that didn't help. Does anyone know how to get rid of this? See screen shot
kpl screen shot.JPG (59.01 KiB) Viewed 660 times
Sat Nov 23, 2019 2:52 pm
Re: Keypadlinc deleting a device
Interesting that a factory reset didn't work - are you sure you got completed it successfully? It's a bit tricky in that after you've pulled out the LED pipe and let it sit, you have to push is from all the way out to depressed in a single motion. If it stops at the normal spot, even briefly, it won't work.
