Who to trace command
Sun Jan 27, 2019 8:51 am
captcurrent offline
Running Indigo 7.0 on 10.12.6
Recently I have found that my thermostat is being reset but not apparently by any of my scripts or setups. This worked with out flaw for quite a long time (in years)
but now I am getting this in log
[quote]
Jan 27, 2019, 9:23:34 AM
Received INSTEON "thermostat" cool setpoint changed to 85.0
Received INSTEON "thermostat" on (button 2)
Received INSTEON "thermostat" heat setpoint changed to 62.0
Trigger Heat Point changes
Email Sent to "security@kasdivi.com"; subject "Heat setting changes"
The event cause the trigger as it is suppose to but the thermostat changes relate to no device or event that I can find.
Any thoughts would be appreciated
Sun Jan 27, 2019 1:24 pm
Re: Who to trace command
Those look like changes caused by manual control on the thermostat itself. Maybe someone pressed the mode button on it?
Sun Jan 27, 2019 3:23 pm
captcurrent offline
i was thinking same thing but no one is there
Tue Jan 29, 2019 8:53 pm
Those commands are definitely originating from the thermostat, and not being sent by Indigo or another module. Is a schedule programmed in the thermostat to change the setpoints at a particular time?
Wed Jan 30, 2019 8:25 am
captcurrent offline
no.. all control is by indigo. I assume that the thermostat, like all insteon devices seem to do, is dying
Users browsing this forum: No registered users and 19 guests
