Some observations: First, I see very different heartbeat intervals across the four instances of this device that I have installed, even though up to now, I have not modified them. Second, battery life on these devices seems mediocre at best. Third, this device has to be physically uninstalled (unscrewed from door frame) in order to change battery. Finally, on at least a few occasions, I have observed dead batteries, but have not received a low-battery warning (group 3) from the device.
Here's my observed heartbeat intervals, extracted from logs:
- Code: Select all
id firm- observed interval between
ware group 4 (heartbeat) messages
#1 45 19:45 (that is, 19 hrs 45 minutes)
#2 43 01:01
#3 45 19:45
#4 43 00:57
Insteon programmer docs (which may be inaccurate or correspond to different hardware/firmware versions) indicate that the heartbeat interval can be sent by sending an extended command. There's also a command in that document to turn off LED.
Sooo.... after some trial and error, I succeeded in creating action groups to send raw Insteon commands to my sensors and was was able to set the heartbeat interval and turn off the LED. ...hopefully will both reduce unnecessary traffic on Insteon and make batteries last longer.
Specific recipes I used:
Turn off LED: send raw. extended=true. commandbyte1 = 0x20, commandbyte2=0x02.
Set Heartbeat (to maximum of ~24 hrs): send-raw. extended=true, commandbyte1=0x2E, commandbyte2=0x00, databyte1:0x00, databyte2:0x02.
It would be nice to see support this capability added to Indigo, perhaps either Interfaces>INSTEON>"Disable Door Sensor LED", and "Set Door Sensor Heartbeat Interval" (similar to commands to set parameters for Insteon motion detectors) or with extra settings in the "Edit Device" dialog (similar to how you set ramp rate, default on-level, for dimmers).
