Just finishing up remodeling our master suite. As part of this I replaced and re-wired all the lights. They are all LED and with the low power usage I put everything on one circuit. However, there are a ton of different switches.
I'm using the DIN 2452-222 lighting controllers, this is the first time I'm using those. I have them all mounted in the basement, with straight runs to the lights they are controlling. The switches for the most part in the suite are not controlling any load, they are just controlling the DIN dimmers.
What I'm experiencing is flicker on these lights whenever another Insteon device is turned on/off or dimmed. Every light that is on in the master suite will flicker for a moment when another switch is activated. This happens with switches that are on different circuits too, almost more so. For example, when I turn a light on in the front yard, totally different breaker in the house, that will cause bedroom lights to flicker.
No other lights in the house (all pretty much LED at this point) get this flicker, just the ones in this new area that we did.
I'm at a loss as to how to trouble shoot this type of interference. Any suggestions?
