Insteon 2477 Dimmer: Indigo only reflects manual off/on
Thu Oct 25, 2018 7:37 pm
hassancy offline
I have a number of 2477 dimmers linked to my Indigo. They correctly reflect whether the state of the dimmer is on or off. However when I manually change the brightness of the light connected to the dimmer to somewhere between 0 and 100, the Event Log does not pick that action up and the state remains at what it was before I pressed the dimmer. If I click on Send Status Request for the dimmer, I get the correct reading. How can make sure that Indigo picks up the correct reading when I manually change it from the dimmer?
Fri Oct 26, 2018 7:00 am
Re: Insteon 2477 Dimmer: Indigo only reflects manual off/on
Try re-syncing the module (from its device dialog). If that doesn't help, then turn it on/off a few times, then dim/brighten it a few times, and copy/paste the Event Log window results into a reply.
Sun Dec 09, 2018 11:26 am
hassancy offline
Resolved
Users browsing this forum: No registered users and 18 guests
