Identify Dual-Band devices
Sun Sep 02, 2018 2:02 pm
tailwheel offline
I'd like some help to clearly identify dual-band Insteon devices.
My device list shows some Insteon Models as "(dual-band)" while others don't show that label -- even though they are dual-band.
In particular, I just swapped out an old SwitchLinc Relay "Firmware: 3A (i2 engine)" with a dual-band SwitchLinc Relay "Firmware: 43 (i2CS engine)". This new switch shows as Model SwitchLinc Relay, with no mention of being "dual-band".
I have a number of other Insteon devices installed for which I'd like to determine their dual-band status.
Is it true that modules prior to the i2CS engine will include "dual-band" in their model description whenever it applies?
Is the i2CS engine used only in those Insteon modules with RF radios, and may or may not indicate as being "dual-band"?
Am I missing anything else?
Best,
Greg
Sun Sep 02, 2018 3:00 pm
Re: Identify Dual-Band devices
I'm not sure that will be the case (but it might be).
Although i2CS doesn't necessarily mean dual-band, I believe any modules that has the i2CS firmware that is AC powered (plugged in, wired in as a switch) is dual-band. Motion detectors and other battery operated modules can be i2CS but are obviously RF only.
Users browsing this forum: No registered users and 27 guests
