Trying to add an Insteon Micro module dimmer(Dual Band)
Sat Sep 01, 2018 8:29 pm
Martin Joseph offline
Trying to install this. All wire up. microswitch on/off works. set works too
Indigo sees the device and then
PowerLinc Linking - entered discovery linking mode (240 seconds)
PowerLinc Linking - syncing PowerLinc links (address 31.16.37)
PowerLinc Linking - . . adding: INSTEON plc link to controller 4D.CE.28, flags 03, group 01, data 00 00 FF
PowerLinc Linking - sync complete
PowerLinc Linking - PowerLinc links updated
PowerLinc Linking - sending engine version request to 4D.CE.28
PowerLinc Linking - received engine version 02 from 4D.CE.28
PowerLinc Linking - sending id request for device information to 4D.CE.28
PowerLinc Linking - received id request response from 4D.CE.28
PowerLinc Linking - initializing remote device "garage light" (address 4D.CE.28, firmware version 48)
PowerLinc Linking - initialize complete
PowerLinc Linking - syncing remote device "garage light" (address 4D.CE.28, firmware version 48)
PowerLinc Linking - syncing all links
Sep 1, 2018, 7:16:30 PM
Error failed to fetch data from remote module
Error Linking - syncing failed
Error linking failed
Sep 1, 2018, 7:17:04 PM
PowerLinc Linking - exited linking mode
I am on Indigo 6.1.11
Mon Sep 03, 2018 12:18 pm
Re: Trying to add an Insteon Micro module dimmer(Dual Band)
The link syncing commands are more susceptible to range and noise problems, so try plugging the PowerLinc into different outlets/circuits using an extension cord to see if you can get it to fully sync.
Mon Sep 03, 2018 10:18 pm
I am using one of those USB thumb drives as my PowerLinc is dead AGAIN! Insteon has really been kind of lame one that front. The central piece of there system is aged and lame, and dies every 24 moths or so. I suppose it's a nice replacement business for them,
I did eventually get this to sync however ;~)
Now I am seeing the same behavior I saw before with my InlineLinc with sense. I spent some time up on a ladder and it looks like the motion sensor isn't properly passing 120V. It hover in the 30V range without motion and then jumps into the 57V range when there is motion.
Ordered a new motion sensor module...
