Problem brewing or already failing.
Posted: Fri May 25, 2018 6:53 pm
I have been on-again-off-again with my smart home, Indigo, and controlling many different items.
My problem is that I lost my server about 2 years ago. I set up another one but didn't do a great job and didn' take the time to re-install Indigo. After a while, that server failed. I went out and got me a new MacMini and got things set up and have been restoring the systems. I've been seeing troubles and working to fix them. Some of the problems were due to the older software, scripts, etc.
I've been working to get things updated and upgraded to 6.1. This cleared up a bunch of things but not everything. That's a long intro and thank you for your patience.
Here are my problems (i think some may be interrelated)
1) I have a 2413U which has been flaky. I have not been able to connect to any of the legacy X10 modules. Monday night, the 2413U died. I found the post for repairing the device, gathered the parts and rebuilt it. It's back working with the Insteon devices but still not with the X10?
2) I decided to make the plunge and further upgrade and this morning purchased the 7.1 upgrade. Just after I purchased it, I spotted the warning about High Sierra. I'm already updated to 10.13.4. Should I hold off on the 7.1 install?
3) I have read several posts that indicate that High Sierra is causing problems. Could both my issues be related to the High Sierra? Should I be planning a reverse migration to 10.12?
Would appreciate input and guidance. Thank you,
