Insteon Sensors - check for dead battery?
Sun May 20, 2018 11:22 am
rbdubz3 offline
I have a number of Insteon sensors - motion, door, leak - kinda stinks that none of them can let you know when the battery level is low. The motion sensor does have an event - but it doesn't seem to work reliably. I am planning to write some code to alert when a sensor device battery appears dead. Not quite a 'low battery' alert, but I am not sure what else to do. At least this will alert me reactively without weeks going by.
I was gonna check the sensor attribute 'lastSuccessfulComm', which looks to happen at least once per day. For door and leak sensors, I see there is a 'heartbeat' event triggered. For some reason Insteon doesn't support heartbeat for Motion Sensors. However, examining my Indigo logs it looks like some type of a status check is done daily by Indigo? This likely updates the 'lastSuccessfulComm' field as well
Anyone else have a good recommendation for alerting on low/dead batteries of Insteon Sensors?
I automate because I am lazy :D - My Plugins: https://forums.indigodomo.com/viewforum.php?f=309
Sun May 20, 2018 11:43 am
Re: Insteon Sensors - check for dead battery?
Mon May 21, 2018 8:30 am
rbdubz3 offline
Thanks Jay.. So I'll be modifying the script for my Insteon Sensors which don't support 'low battery' - it'll be more of a 'Dead Battery' than 'Low Battery' notification - but I'll take what I can get.
Is 'lastChanged' the best attribute for checking? I did see 'lastSuccessfulComm' as well. I've been scanning these manually in the last day and they look to be the same. I was thinking 'lastSuccessfulComm' sounded better since it should be updated even if the device state didn't change (I'd think)
Users browsing this forum: No registered users and 18 guests
