Error Turning on a Light
Sat Apr 28, 2018 8:57 am
ckeyes888 offline
Just started getting this error when turning on a kitchen light.
It eventually does turn on/off but after a few seconds delay.
Sent INSTEON                    "Kitchen Overhead Lights" on
   Virtual Devices Error           Error #931: updateScene failed on Device Group 1344630331.
  File "plugin.py", line 358, in updateScene
AttributeError: 'Device' object has no attribute 'onState'
Any idea what it may be?
Carl
Sun Apr 29, 2018 11:19 am
Re: Error Turning on a Light
Looks like maybe you have a Virtual Device group that contains a device that isn't a relay or dimmer. That is, it doesn't have an on/off state which is causing the plugin to fail.
I'm not sure how it got into that state. I wouldn't have thought the plugin would allow you to add that, but maybe the device type was changed after-the-fact. Perhaps you replace or swapped (and re-synced) a device and it is now a different type?
Sun Apr 29, 2018 5:32 pm
ckeyes888 offline
Thanks Matt. I reloaded the Meta Device plugin a couple times and the error ended.
Odd one for sure.
Carl
Mon Apr 30, 2018 9:32 am
That means that a device in a Device Group didn't/doesn't have an onState property. This means that at some point AFTER the device was added to the group (since you can only add devices that have an onState property), it's device type changed somehow (probably because the device was redefined). The next time the DG started up after the change, I believe it should have self-corrected.
Tue May 15, 2018 7:27 pm
ckeyes888 offline
The error came back and restarting the Meta Device plugin isn’t fixing it.
I don’t use any device groups so not sure at all how this is happening.
Any idea how to troubleshoot?
Carl
Wed May 16, 2018 9:27 am
I suspect that you have a device that's sometimes enabled and sometimes disabled. That device would be the one that no longer has an onState property. The fastest way to diagnose the problem is to look at the Device Group with ID 1344630331 to see which device doesn't have an onState property (it won't show up in the Indigo UI as any type of on/off device).
You can also enable debugging and see what debug information gets logged immediately before and after the error line in the Event Log.
Wed May 16, 2018 9:46 am
ckeyes888 offline
I don’t have an Action Group with that ID that I can find.
Some other way to locate it?
Carl
Users browsing this forum: No registered users and 21 guests
