[SOLVED]: Failed to Link
Fri Aug 22, 2014 7:45 pm
gskarp offline
I have been trying to link an insteon garage door controller and it seems to always fail. I even plugged it into an outlet right next to where the insteon controller is plugged into and still no luck. Should I assume it's a faulty module?
Here's the log:
PowerLinc Linking - syncing PowerLinc links (address 18.D3.E3)
PowerLinc Linking - . . adding: INSTEON plc link to controller 2B.FA.CC, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . adding: (not added -- probably already exists)
PowerLinc Linking - sync complete
PowerLinc Linking - sending engine version request to 2B.FA.CC
PowerLinc Linking - PowerLinc links updated
PowerLinc Linking - adding PowerLinc to module's database
Error Linking - device failed to send engine version information
Error linking failed
PowerLinc Linking - entered discovery linking mode (240 seconds)
PowerLinc Linking - received module button pressed from 2B.FA.CC
PowerLinc Linking - exited linking mode
Sat Aug 23, 2014 10:11 am
gskarp offline
Re: Failed to Link
Nevermind. I ran the troubleshooting Reset Powerlinc and sync links from the preferences section and it seemed to fix it. It now recognizes the module. Hopefully it reaches the garage.
Sat Aug 23, 2014 10:37 am
HFTobeason offline
Re: Failed to Link
I just had the same problem. I bought new SwitchLinc #2477S modules to replace several failed 1st generation modules. Upon installing the new modules, I got exactly the same error:
    PowerLinc Linking - received module button pressed from 2F.E8.E3
    PowerLinc Linking - copying all links from old address to new address
    PowerLinc Linking - sending engine version request to 2F.E8.E3
    PowerLinc Linking - syncing PowerLinc links (address 0E.DD.E9)
    PowerLinc Linking - . . adding: INSTEON plc link to controller 2F.E8.E3, flags 03, group 01, data 00 00 FF
I went to: Preferences->Interfaces->INSTEON / X10 Power Line Interface->Configure->Interface Options and clicked "Reset PowerLinc and Sync Links".
That solved the problem.
Sat May 30, 2015 10:20 am
wexler offline
Re: Failed to Link
WOW - that worked! I was installing the new dual-band devices and I couldn't get the to work (e.g. 2477S switch) and after executed your recommendation above, it worked! Thank you!
Fri Apr 01, 2016 5:22 pm
tornado offline
Re: [SOLVED]: Failed to Link
I bought a lamplinc on eBay and am having a hard time linking it to Indigo.
I've tried the reset, and I've also tried a factory reset on the lamp linc.
Any suggestions?
Apr 1, 2016, 4:13:45 PM
  PowerLinc                       Resetting...
  PowerLinc                       Reset complete (all links cleared)
  PowerLinc                       Linking - comparing local and powerlinc links
  PowerLinc                       Linking - .  missing: remote link not found for persistent link 01.1C.B6 group 01 (adding remote link)
  PowerLinc                       Linking - .  missing: remote link not found for persistent link 00.5B.B0 group 01 (adding remote link)
  PowerLinc                       Linking - .  missing: remote link not found for persistent link 00.02.98 group 01 (adding remote link)
  PowerLinc                       Linking - .  missing: remote link not found for persistent link 05.06.2E group 01 (adding remote link)
  PowerLinc                       Linking - .  missing: remote link not found for persistent link 0E.60.2E group 01 (adding remote link)
  PowerLinc                       Linking - .  missing: remote link not found for persistent link 0E.60.2F group 01 (adding remote link)
  PowerLinc                       Linking - .  missing: remote link not found for persistent link 07.B5.EE group 01 (adding remote link)
  PowerLinc                       Linking - .  missing: remote link not found for persistent link 05.37.8E group 01 (adding remote link)
  PowerLinc                       Linking - .  missing: remote link not found for persistent link 18.F4.20 group 01 (adding remote link)
  PowerLinc                       Linking - .  missing: remote link not found for persistent link 2F.73.84 group 01 (adding remote link)
  PowerLinc                       Linking - .  missing: remote link not found for persistent link 31.6F.6B group 01 (adding remote link)
  PowerLinc                       Linking - .  missing: remote link not found for persistent link 28.33.C4 group 01 (adding remote link)
  PowerLinc                       Linking - .  missing: remote link not found for persistent link 36.9D.BD group 01 (adding remote link)
  PowerLinc                       Linking - .  missing: remote link not found for persistent link 3A.DB.A1 group 01 (adding remote link)
  PowerLinc                       Linking - .  missing: remote link not found for persistent link 2D.97.68 group 01 (adding remote link)
  PowerLinc                       Linking - .  missing: remote link not found for persistent link 2D.95.35 group 01 (adding remote link)
  PowerLinc                       Linking - .  missing: remote link not found for persistent link 27.39.E3 group 01 (adding remote link)
  PowerLinc                       Linking - .  missing: remote link not found for persistent link 27.36.FD group 01 (adding remote link)
  PowerLinc                       Linking - compare complete
  PowerLinc                       Linking - . . adding: INSTEON plc link to controller 01.1C.B6, flags 03, group 01, data 00 00 FF
  PowerLinc                       Linking - . . adding: INSTEON plc link to controller 00.5B.B0, flags 03, group 01, data 00 00 FF
  PowerLinc                       Linking - . . adding: INSTEON plc link to controller 00.02.98, flags 03, group 01, data 00 00 FF
  PowerLinc                       Linking - . . adding: INSTEON plc link to controller 05.06.2E, flags 03, group 01, data 00 00 FF
  PowerLinc                       Linking - . . adding: INSTEON plc link to controller 0E.60.2E, flags 03, group 01, data 00 00 FF
  PowerLinc                       Linking - . . adding: INSTEON plc link to controller 0E.60.2F, flags 03, group 01, data 00 00 FF
  PowerLinc                       Linking - . . adding: INSTEON plc link to controller 07.B5.EE, flags 03, group 01, data 00 00 FF
  PowerLinc                       Linking - . . adding: INSTEON plc link to controller 05.37.8E, flags 03, group 01, data 00 00 FF
  PowerLinc                       Linking - . . adding: INSTEON plc link to controller 18.F4.20, flags 03, group 01, data 00 00 FF
  PowerLinc                       Linking - . . adding: INSTEON plc link to controller 2F.73.84, flags 03, group 01, data 00 00 FF
  PowerLinc                       Linking - . . adding: INSTEON plc link to controller 31.6F.6B, flags 03, group 01, data 00 00 FF
  PowerLinc                       Linking - . . adding: INSTEON plc link to controller 28.33.C4, flags 03, group 01, data 00 00 FF
  PowerLinc                       Linking - . . adding: INSTEON plc link to controller 36.9D.BD, flags 03, group 01, data 00 00 FF
  PowerLinc                       Linking - . . adding: INSTEON plc link to controller 3A.DB.A1, flags 03, group 01, data 00 00 FF
  PowerLinc                       Linking - . . adding: INSTEON plc link to controller 2D.97.68, flags 03, group 01, data 00 00 FF
  PowerLinc                       Linking - . . adding: INSTEON plc link to controller 2D.95.35, flags 03, group 01, data 00 00 FF
  PowerLinc                       Linking - . . adding: INSTEON plc link to controller 27.39.E3, flags 03, group 01, data 00 00 FF
  PowerLinc                       Linking - . . adding: INSTEON plc link to controller 27.36.FD, flags 03, group 01, data 00 00 FF
  PowerLinc                       Linking - received module button pressed from 27.36.FD
  PowerLinc                       Linking - syncing PowerLinc links (address 2B.93.F3)
  PowerLinc                       Linking - sending engine version request to 27.36.FD
Fri Apr 01, 2016 5:58 pm
Looks like the LampLinc isn't responding at all. Do you have it plugged into the same outlet (or power strip) as the PowerLinc? That will help rule out signal problems.
Fri Apr 01, 2016 10:41 pm
tornado offline
I do now; it is doing the same thing :(
Any other suggestions?
Sat Apr 02, 2016 10:23 am
Do you have any other INSTEON modules and can you define/sync those currently?
I'm wondering if the LampLinc might be a bad. I know we've had reports of some ebay purchased modules not work well (especially for the PowerLinc).
Wed Nov 17, 2021 9:46 pm
hamw offline
Replaced a 240v relay. Trying to sync. Appears to work but then can't fetch data from the module. I can't plug it into the same outlet as the powerlinc, unfortunately.
   PowerLinc                       Linking - sending engine version request to 3F.2E.0A
   PowerLinc                       Linking - received engine version 02 from 3F.2E.0A
   PowerLinc                       Linking - sending id request for device information to 3F.2E.0A
   PowerLinc                       Linking - received id request response from 3F.2E.0A
   PowerLinc                       Linking - initializing remote device "GA Hot Water Heater" (address 3F.2E.0A, firmware version 9E)
   PowerLinc                       Linking - initialize complete
   PowerLinc                       Linking - syncing remote device "GA Hot Water Heater" (address 3F.2E.0A, firmware version 9E)
   PowerLinc                       Linking - syncing all links
   Error                           failed to fetch data from remote module
   Error                           Linking - syncing failed
   PowerLinc                       Linking - syncing PowerLinc links (address 3C.4C.82)
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 3F.2E.0A, flags 03, group 01, data 00 00 FF
Tried with the module on and also off. Any thoughts? I have had a couple of others and they all sync'd without difficulty. I also tried the "reset powerlinc and reset links" as described above, without success.
Thu Nov 18, 2021 4:05 pm
Use an extension cord to try plugging the PowerLinc into different outlet / circuits (if possible the same circuit as the module) to see if you can get the sync to complete.
