Folks,
Here's the situation... Twice I have received kernel panics in 10.4.3 with Indigo 1.80.
I "upgraded" to an Insteon starter kit, and unplugged the 1142USB controller from the wall but left it plugged in to the USB port.
Indigo correctly identified the new Insteon controller and upgraded the firmware...
The first kernel panic occurred when I added an Insteon device, but left the add devices panel open waiting for input for several minutes.
The second time I believe that Indigo was open, but sitting idle.
The only clue I have is that in the background of the Panic, Indigo had indicated that the CU1132USB had reported no AC detected.
I believe that having both an 1132CU & Insteon controller connected may be a "bad idea" (TM)? Or at least make sure both are plugged into the wall!
Since removing the 1132CU from the USB cable the system has been perfectly stable.
Anyone interested in some X-10 units relatively cheap?
- Ben
