Hi Matt,
Here's the scenario, I have a motion detector (MS14A) controlling the LampLinc in the living room. I do the X10 -> Insteon translation in Indigo and send a "set brightness to 35%" command (a "device on" goes to 100% even after setting the initial "on level" with a ControLinc). The 35% light level is good for conversation & audio/video. I use an IR remote to set brightness to 100% for reading. Works well. Until you move your leg
The MS14A then turns the level back to 35%. And as I said, having the MS14A trigger action send a device on, the lamp would always come on to 100%.
All worked well using an X10 version LampLinc. A "device on" from the MS14A would not change the brightness level that was last used. It seems to me the Insteon LampLinc does not emulate the X10 "resume dim" mentioned in the X10 section of the Insteon LampLinc user manual.
Any ideas ? (Aside from trashing the MS14A which I'll probably have to do...)
Ken
