ICON Lamp Dimmer - 2856D2B
For maximum lighting control throughout your home, plug each lamp into the only dimmer compatible with the revolutionary INSTEON technology, where messages are transmitted throughout your home both wirelessly and through the home's electrical wiring.
ICON Appliance Module - 2856S3B
Make your home the envy of your friends and neighbors with the sophistication and elegance of the ICON Dimmer Switch.
INSTEON SwitchLinc V2 Timer - 2476st
It's a Switchlinc V2 Relay with a built it 15 minute timer to turn off the light. Double tap gives you 1 hr, and each tap after that adds an extra hr to the timer up to 24 hrs. Holding the top for 2 seconds will leave the switch on until its turned off.
Very cool! Smarthome sure is cranking out the new INSTEON devices.
