ricks wrote:On another note, it seems that if the EZIO8T is unplugged that it loses it's settings (1-wire no longer functions, only returns "255"). Forcing the re-upolad of the settings through "Edit EZIO settings" fixes it (until the next power outage). EZIO8T firmware is now 1.7.
Bummer. Yes, I think this is an EZIO8T issue. Indigo always (when you press the Set All button) tells the EZIOxx's to load the EEPROM with the RAM changes. My EZIO8SA with firmware 1.5 retains all of its settings (including 1-wire) after I unplug it.
Update: I just checked the code to see when Indigo tells the EZIOxx to update the EEPROM. It definitely does it whenever you set an alarm trip point OR when you set an output timer. So change your 1-wire sensor trip point sensor values.
There is also a bug in the current build that does not set the 1-wire sensor state if the "Enable analog inputs" is not on. So turn that checkbox ON as well. This will be fixed in the next build.
So, hopefully your issue is indeed related to the above Indigo buglet and not a firmware issue...
Regards,
Matt
