When will the Insteon Siren 2868-222 be better supported?
Mon Dec 10, 2018 7:01 pm
peszko offline
Re: When will the Insteon Siren 2868-222 be better supported
I'd also like to ask for a better implementation. At this point, even the initial linking isn't really working as it needs to be done manually. Even then, it is not obvious how to trigger each action.
Wed Dec 12, 2018 8:42 pm
Thanks for the feedback. Adding some customer commands for the siren is definitely on our request list.
Wed Dec 12, 2018 9:24 pm
Fishysan offline
Awesome Matt, thanks. I've two of them also. Cheers!
Tue Dec 18, 2018 8:05 pm
peszko offline
Actually, just started moving to z-wave after my latest all on insteon glitch so might not want to install it anyway. I hope to get better stability and response from the switches, and there seems to be way way more choices for modules.
Sun May 12, 2019 6:47 pm
auto_man offline
I tried to use the new commands for setting the Insteon Siren between the siren and chime sounds, but I get the following error:
INSTEON Commands Error plugin does not define method setCurrentAlarmType
Anyone experience this or have ideas about it?
Sun May 12, 2019 8:18 pm
Looks like we have a buglet. We are investigating – thanks for the report.
Mon May 13, 2019 7:18 am
Fishysan offline
Awesome.. and more support is appreciated! Have two of them now, plans for 3rd pending functions.
Cheers.
Thu May 23, 2019 8:41 pm
hamw offline
Wanted to report the same as above. Would appreciate if you all could push out a quick fix so we can use these things.... 7.3.0001 would be just fine!
Ham
Trigger                         Doorbell Rings Siren 3
   Updated                         "SmokeBridge 3 Main Attic" on
Fri May 24, 2019 10:41 am
Have you tried 7.3.1? I think it might have made it into that release.
Fri May 24, 2019 2:41 pm
Afraid that one was discovered right after we released 7.3.1. It'll be fixed in 7.3.2 for sure.
Mon Sep 30, 2019 4:03 pm
Indigo 7.4 is now available and fixes the bug above.
Sun Jan 19, 2020 9:22 am
hamw offline
Unless there is some other plugin update or something else I need to do, it appears to still be broken in 7.4..... I resync'd the device and used the new menu setting to try to set to chime. It does not work via Indigo command. However I can turn it on and off manually from the devices menu.
   INSTEON Commands Error          plugin does not define method setCurrentAlarmType  <<<<<<<<<<<<<<<< trying to get it to set chime vs siren on the fly
   Schedule                        Doorbell Rings Siren 3 (delayed action)
   Updated                         "SmokeBridge 3 Main Attic" off
Tried define and sync again per instructions, and ran the unit turning on and off only via Indigo actions. Still no joy.....
Jan 19, 2020 at 10:17:30 AM
   Sent INSTEON                    broadcast set button down
   PowerLinc                       Linking - entered discovery linking mode (240 seconds)
   PowerLinc                       Linking - sending engine version request to 3F.0B.AC
   PowerLinc                       Unexpected command 02 0B (flushing)
   PowerLinc                       Linking - received engine version 02 from 3F.0B.AC
   PowerLinc                       Linking - sending id request for device information to 3F.0B.AC
   PowerLinc                       Linking - received id request response from 3F.0B.AC
   PowerLinc                       Linking - initializing remote device "Insteon Siren 3" (address 3F.0B.AC, firmware version 45)
   PowerLinc                       Linking - initialize complete
   PowerLinc                       Linking - syncing remote device "Insteon Siren 3" (address 3F.0B.AC, firmware version 45)
   PowerLinc                       Linking - syncing of this device not possible remotely (skipping)  <<<<<<<<<<<<<<<<<<<<<Don't understand this.
   PowerLinc                       Linking - sync complete
   PowerLinc                       Linking - syncing PowerLinc links (address 3C.4C.82)
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 3F.0B.AC, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: (not added -- probably already exists)
   PowerLinc                       Linking - PowerLinc links updated
   PowerLinc                       Linking - exited linking mode
Jan 19, 2020 at 10:18:40 AM
   Received INSTEON                "Thermostat Fam Room" temperature changed to 67.0
Thoughts?
Mon Jan 20, 2020 8:05 pm
Can you open the Terminal window and copy/paste in the following lines and copy into a reply the result for me?
cd /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7.4
more Plugins/.INSTEON\ Commands.indigoPlugin/Contents/Info.plist
Tue Jan 21, 2020 10:06 pm
hamw offline
Last login: Tue Jan 21 22:59:43 on ttys000
Hamiltons-Mac-mini:~ hamiltonwilliams$ cd /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7.4
Hamiltons-Mac-mini:Indigo 7.4 hamiltonwilliams$ more Plugins/.INSTEON\ Commands.indigoPlugin/Contents/Info.plist
<plist version="1.0">
<dict>
        <key>PluginVersion</key>
        <string>2.2.2</string>
        <key>ServerApiVersion</key>
        <string>2.0</string>
        <key>IwsApiVersion</key>
        <string>1.0</string>
        <string>INSTEON Commands</string>
        <key>CFBundleIdentifier</key>
        <string>com.perceptiveautomation.indigoplugin.InsteonCommands</string>
        <key>CFBundleVersion</key>
        <string>1.0.0</string>
        <key>CFBundleURLTypes</key>
        <array>
                <dict>
                        <key>CFBundleURLName</key>
                        <string>http://wiki.indigodomo.com/doku.php?id=plugins:insteon_commands</string>
Plugins/.INSTEON\ Commands.indigoPlugin/Contents/Info.plist...skipping...
<dict>
        <array>
                <dict>
                </dict>
:...skipping...
<dict>
        <array>
                <dict>
                </dict>
        </array>
:...skipping...
<dict>
        <array>
                <dict>
                </dict>
        </array>
</dict>
:...skipping...
<dict>
        <array>
                <dict>
                </dict>
        </array>
</dict>
</plist>
(END)
<dict>
        <array>
                <dict>
                </dict>
        </array>
</dict>
</plist>
(END)...skipping...
<dict>
        <array>
                <dict>
                </dict>
        </array>
</dict>
</plist>
(END)
<dict>
        <array>
                <dict>
                </dict>
        </array>
</dict>
</plist>
(END)
<dict>
        <array>
                <dict>
                </dict>
        </array>
</dict>
</plist>
(END)...skipping...
<dict>
        <array>
                <dict>
                </dict>
        </array>
</dict>
</plist>
(END)
<dict>
        <array>
                <dict>
                </dict>
        </array>
</dict>
</plist>
(END)
<dict>
        <array>
                <dict>
                </dict>
        </array>
</dict>
</plist>
(END)...skipping...
<dict>
        <array>
                <dict>
                </dict>
        </array>
</dict>
</plist>
(END)
<dict>
        <array>
                <dict>
                </dict>
        </array>
</dict>
</plist>
(END)
Wed Jan 22, 2020 10:38 am
I'm not sure how it happened, but you don't have the version of the Insteon Commands plugin that was included in 7.4.0. Your version is older. Try stopping the Indigo Server and re-running the 7.4.0 installer.
