I have a Insteon Remote Control Dual On/Off Outlet that I have linked to an eight button KPL. If I press the KPL button (7) assigned to the TOP Outlet linc, the KPL button (7) lights up and the TOP outletlinc is turned on and if I turn off the KPL button (7) the KPL button (7) light goes off and the TOP outlet turns off - as it should.
However, if I turn the Outletlinc on with the KPL button (7) and then turn off the Outletlinc remotely (as in a control page) - the TOP outletlinc will turn off; however the KPL button (7) stays on. The same occurs if I remotely turn on the TOP outletlinc - the KPL button (7) light does not come on.
How can I remotely turn off/on an outletlinc and have the KPL button (7) turn off/on (sync)?
I have tried to set up a DEVICE LINK on the OUTLET LINC - using the KPL button 7 as the responder device. However the linking fails ...
Error failed to fetch data from remote module
Error Linking - syncing failed
The responder device remains "GREEN" with the status as "added - sync needed"
