It has worked but right now the OFF command and all "Send Button Commands" are not working. But the On Command works..
Below is the debug code:
Action Group Sony OFF copy
Sony Bravia Network Remote Plugin Threaddebug Returning default GUIConfigValue for sonyTvRemoteDevice:deviceIsChildDevice
Sony Bravia Network Remote Plugin Debug Concurrent Processing Thread started for device 71951009
Sony Bravia Network Remote Plugin Threaddebug Returning default GUIConfigValue for sonyTvRemoteDevice:updateStatusPollerIntervalProperty
Sony Bravia Network Remote Plugin Threaddebug Returning default GUIConfigValue for sonyTvRemoteDevice:updateStatusPollerActionId
Sony Bravia Network Remote Plugin Threaddebug Returning default GUIConfigValue for sonyTvRemoteDevice:emptyQueueReducedWaitCycles
Sony Bravia Network Remote Plugin Threaddebug Returning default GUIConfigValue for sonyTvRemoteDevice:databaseConnectionEnabled
Sony Bravia Network Remote Plugin Threaddebug Database access enabled:
Sony Bravia Network Remote Plugin Threaddebug Database access has been disabled, skipping connection
Sony Bravia Network Remote Plugin Threaddebug Command queue has 1 command(s) waiting
Sony Bravia Network Remote Plugin Threaddebug Received SOAP/JSON command request:
/sony/IRCC
urn:schemas-sony-com:service:IRCC:1#X_SendIRCC
<SOAP-ENV:Envelope SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
<SOAP-ENV:Body>
<m:X_SendIRCC xmlns:m="urn:schemas-sony-com:service:IRCC:1">
<IRCCCode xmlns:dt="urn:schemas-microsoft-com:datatypes" dt:dt="string">AAAAAQAAAAEAAAAvAw==</IRCCCode>
</m:X_SendIRCC>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
Sony Bravia Network Remote Plugin Debug Processing SOAP/JSON operation to http://192.168.1.59:80/sony/IRCC
Sony Bravia Network Remote Plugin Threaddebug Sending SOAP/JSON request:
<SOAP-ENV:Body>
</m:X_SendIRCC>
</SOAP-ENV:Body>
Sony Bravia Network Remote Plugin Threaddebug Using headers:
{'SOAPAction': 'urn:schemas-sony-com:service:IRCC:1#X_SendIRCC', 'Host': u'192.168.1.59', 'Content-type': 'text/xml; charset="UTF-8"', 'User-Agent': 'DuncanwareRemote (IndigoPlugin)'}
Sony Bravia Network Remote Plugin Received an authentication request, attempting now...
Sony Bravia Network Remote Plugin Error Error in plugin execution:
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sony Bravia Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkRESTfulDevice.py", line 362, in concurrentCommandProcessingThread
self.handleRESTfulError(command, e, responseObj)
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sony Bravia Network Remote.indigoPlugin/Contents/Server Plugin/sonyTvNetworkRemoteDevice.py", line 159, in handleRESTfulError
self.commandQueue.put(RPFrameworkCommand.RPFrameworkCommand(CMD_AUTHENTICATE_TO_DEVICE, commandPayload=rpCommand.commandPayload))
NameError: global name 'RPFrameworkCommand' is not defined
