“can’t compare datetime.datetime to int” error during lime
PostPosted: Mon Apr 25, 2016 3:40 am
by durosity
Got a strange error today during Lime Protection:
25 Apr 2016, 10:30:56
  Autolog Stella-Z                Lime Protection now in progress.
  Autolog Stella-Z Error          Error detected in Autolog Plugin runConcurrentThread Method 'E'
  Autolog Stella-Z Error            Error message: ''RelayDevice' object has no attribute 'hvacMode''
25 Apr 2016, 10:31:57
  Autolog Stella-Z Error            Error message: 'can't compare datetime.datetime to int'
25 Apr 2016, 10:32:58
25 Apr 2016, 10:33:37
  Z-Wave                          received "Ensuite - Danfoss LC TRV" heat setpoint is 17.00 °C
25 Apr 2016, 10:33:57
  Z-Wave                          received "045 - Gym - Stella Z TRV" status update battery level 76%
25 Apr 2016, 10:35:00
  Autolog Stella-Z                Lime Protection now completed
Not sure if it actually ran it or not, and didn’t have a chance to turn on debug before it was finished. I can try it again manually if it’s needed.
Re: “can’t compare datetime.datetime to int” error during li
PostPosted: Mon Apr 25, 2016 7:57 am
by autolog
Has this only just started happening? If so, have you changed anything recently?
It looks like it is checking a relay device rather than a Stella-Z. It is possible this could be your boiler connect device?
I'll dig into it a bit deeper once I have some more info. :)
PostPosted: Fri Apr 29, 2016 8:32 am
by durosity
Nope, nothing that’s change in relation to that part of the system afaik. in fact very little changes anywhere in indigo. I’ve not seen the error before but then if it only happens once a week during the day when i’m usually at work it’s unlikely i would have seen it. When i’m back home i’ll turn on debug logging and try to run a manual one, see if it does the same.
