Tue Jul 31, 2018 12:44 am
yassi offline
Hi guys,
I mean, we still have summer, but the winter is coming... :cry:
Thinking of getting the new Eurotronics Spirits (at the moment cheap here in Germany).
@Jon, do you think the plugin will be ready in the next 2-3 months?
Yassi
Tue Jul 31, 2018 2:28 am
autolog offline
yassi wrote:
Hi guys,
Yassi
I am not going to promise anything but I will see what I can do. :)
Thu Aug 09, 2018 9:30 pm
bullsim offline
@autolog a life event has just occcured for myself and so beginning to ne d to get out heating ready as I know I will
Need to use it soon. Any news on the spirit support? Anything o can do to help it?
Simon
Fri Aug 10, 2018 1:51 am
siclark offline
Congratulations? Is that the same life event that I am preparing for that will require precise control over heating in a bedroom?
Simon
Fri Aug 10, 2018 2:15 am
siclark offline
and on that note, does this plugin work on Popp/Devolo TRVs? I have been controlling them manually, but would like to get easier control on them.
Fri Aug 10, 2018 2:29 am
autolog offline
I will start looking at this in a short while - I have Spirit Thermostats and I would like to support them better :)
Fri Aug 10, 2018 2:31 am
autolog offline
The plugin supports Popp thermostats and I have a number in use. :)
Fri Aug 10, 2018 3:06 am
siclark offline
Perfect.. thanks.
Fri Aug 10, 2018 4:50 pm
siclark offline
Ah. Popp is great but I also have Devolo TRVs. Are these supported?
Sat Aug 11, 2018 3:06 am
autolog offline
Possibly (I haven't got a Devolo) - I might need to do a minor change to support them. Best thing would be to try them and see.
If they don't work, then do a print of the device of the device to the Indigo log and paste the results here.
Run a server script action:
indigo.server.log(u'Devolo - Thermostat:\n %s' % (indigo.devices[12345678])) # "Devolo - Thermostat"
where 12345678 is the Indigo device ID of the Devolo Thermostat. :)
Fri Aug 17, 2018 5:01 am
siclark offline
Here you go. I am pretty sure the Devolo is just a rebadged Popp, the hardware looks identical at least. Not sure about the firmware.
Script Devolo - Thermostat:
address : 17
batteryLevel : 66
buttonGroupCount : 0
configured : True
coolIsOn : False
coolSetpoint : 0.0
dehumidifierIsOn : False
description :
deviceTypeId : zwThermostatType
displayStateId : temperatureInputsAll
displayStateImageSel : HvacOff
displayStateValRaw : 20.9
displayStateValUi : 20.9
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
fanIsOn : False
fanMode : Auto
folderId : 1335677605
com.perceptiveautomation.indigoplugin.zwave : (dict)
NumHumidityInputs : 0 (integer)
NumTemperatureInputs : 1 (integer)
SetpointPrecision : 1 (integer)
ShowCoolHeatEquipmentStateUI : false (bool)
SupportsBatteryLevel : true (bool)
SupportsCoolSetpoint : false (bool)
SupportsHeatSetpoint : true (bool)
SupportsHvacFanMode : false (bool)
SupportsHvacOperationMode : false (bool)
TempUnits : 1 (integer)
address : 17 (integer)
disableStatusLogging : false (bool)
disableTempLogging : true (bool)
indigoObjVersion : 6 (integer)
modelNameAndFirmware : Radiator Thermostat (Devolo 09356), firmware 1.00 (string)
propsPushTickler : 3 (string)
tempAlwaysFalse : false (bool)
userPollAfterActivity : true (bool)
userPollInterval : 0 (integer)
userPollingEnabled : true (bool)
userWakeInterval : 15 (integer)
version : 1.00 (string)
zwAppVersMajor : 1 (integer)
zwAppVersMinor : 0 (integer)
zwAssociationsMap : (dict)
zwAssociationsMapStr : - none - (string)
zwClassCmdBase : 67 (integer)
zwClassCmdMap : (dict)
c114 : 1 (integer)
c117 : 1 (integer)
c128 : 1 (integer)
c129 : 1 (integer)
c132 : 2 (integer)
c134 : 1 (integer)
c143 : 1 (integer)
c32 : 1 (integer)
c49 : 6 (integer)
c67 : 1 (integer)
c70 : 1 (integer)
zwClassCmdMapStr : 20v1 80v1 43v1 84v2 46v1 86v1 81v1 8Fv1 31v6 72v1 75v1 (string)
zwClassIds : (list)
Item : 4 (integer)
Item : 8 (integer)
Item : 4 (integer)
zwClassInstanceCountMap : (dict)
zwClassInstanceCountMapStr : - none - (string)
zwClassName : Setpoint Thermostat (string)
zwConfigVals : (dict)
zwConfigValsStr : - none - (string)
zwDevSubIndex : 0 (integer)
zwEncryptClassCmdMap : (dict)
zwEncryptClassCmdMapStr : - none - (string)
zwEncryptionStatusStr : Not Supported (string)
zwEndpointClassMap : (dict)
zwEndpointClassMapStr : - none - (string)
zwEndpointDevTypeMap : (dict)
zwEndpointDevTypeMapStr : - none - (string)
zwFeatureListStr : routing, battery, beaming, waking (string)
zwLibType : 6 (integer)
zwManufactureId : 2 (integer)
zwManufactureName : Danfoss (string)
zwModelDefnVers : 3 (integer)
zwModelId : 328053 (integer)
zwModelName : Radiator Thermostat (Devolo 09356) (string)
zwNodeNeighbors : (list)
Item : 2 (integer)
Item : 3 (integer)
Item : 4 (integer)
Item : 6 (integer)
Item : 8 (integer)
Item : 13 (integer)
Item : 28 (integer)
Item : 29 (integer)
Item : 30 (integer)
Item : 34 (integer)
Item : 37 (integer)
zwNodeNeighborsStr : 2, 3, 4, 6, 8, 13, 28, 29, 30, 34, 37 (string)
zwProtoVersMajor : 3 (integer)
zwProtoVersMinor : 67 (integer)
zwShowDumpDevToLog : true (bool)
zwShowMainUI : true (bool)
zwShowManualModifyConfigParmUI : true (bool)
zwShowPollingUI : false (bool)
zwShowSubmitModelInfoUI : false (bool)
zwShowWakeIntervalUI : true (bool)
zwWakeInterval : 15 (integer)
heatIsOn : False
heatSetpoint : 16.0
humidities : []
humiditySensorCount : 0
hvacMode : Heat
lastChanged : 2018-08-17 11:38:07
lastSuccessfulComm : 2018-08-17 11:38:07
model : Radiator Thermostat (Devolo 09356)
name : Garden Room Radiator
ownerProps : com.perceptiveautomation.indigoplugin.zwave : (dict)
c114 : 1 (integer)
c117 : 1 (integer)
c128 : 1 (integer)
c129 : 1 (integer)
c132 : 2 (integer)
c134 : 1 (integer)
c143 : 1 (integer)
c32 : 1 (integer)
c49 : 6 (integer)
c67 : 1 (integer)
c70 : 1 (integer)
zwClassIds : (list)
Item : 4 (integer)
Item : 8 (integer)
Item : 4 (integer)
Item : 2 (integer)
Item : 3 (integer)
Item : 4 (integer)
Item : 6 (integer)
Item : 8 (integer)
Item : 13 (integer)
Item : 28 (integer)
Item : 29 (integer)
Item : 30 (integer)
Item : 34 (integer)
Item : 37 (integer)
pluginId : com.perceptiveautomation.indigoplugin.zwave
protocol : ZWave
remoteDisplay : True
states : States : (dict)
batteryLevel : 66 (integer)
batteryLevel.ui : 66% (string)
setpointHeat : 16 (real)
setpointHeat.ui : 16.00 °C (string)
temperatureInput1 : 20.9 (real)
temperatureInput1.ui : 20.92 °C (string)
temperatureInputsAll : 20.9 (string)
subModel :
supportsAllOff : False
supportsCoolSetpoint : False
supportsHeatSetpoint : True
supportsHvacFanMode : False
supportsHvacOperationMode : False
supportsStatusRequest : False
temperatureSensorCount : 1
temperatures : [20.9]
version : 1.00
Mon Aug 20, 2018 11:37 am
autolog offline
siclark wrote:
Here you go. I am pretty sure the Devolo is just a rebadged Popp, the hardware looks identical at least. Not sure about the firmware. ...
I have done the very minor change (untested and the only change when compared to the previous version). Hopefully it should now support the Devolo - pre-release available here: 2.3.7 Release
Let me know whether it works or not :)
Mon Sep 10, 2018 3:55 pm
siclark offline
Cheers... finally got round to testing and it looks to be working. Its setup (with a dummy meta device for the heating control) now to understand how to use it!
Sun Sep 30, 2018 1:43 pm
autolog offline
Please see this sub-forum for an update on the new TRV Controller I am now working on :) : TRV Controller
Sat Oct 06, 2018 4:06 am
bullsim offline
So happy to see this, a million thanks. my recovery is going well too :D
