Google Voice SMS Plugin
Thu Nov 07, 2013 10:57 am
bschollnick2 offline
Re: Google Voice SMS Plugin for Indigo 5 (SIRI support added
Dewster35 wrote:
Ben.... see link for updated plugin with variable substitution added.
https://www.dropbox.com/sh/piynzn02dkrfiza/TZbS59iEcF
Thanks for the link, that version is doing effectively the same thing that I am doing in my version of the plugin.
I did take your code, and try it, with the same results. Executing the Trigger does fire the plugin off correctly, but the variable substitution does not seem to be occurring.
- Benjamin
for v5 - http://bit.ly/T6WBKu
Thu Nov 07, 2013 11:04 am
Dewster35 offline
Ben... not sure what to tell you. All that was modified the plugin.py file and I am sending %%v:376374459%% (With all of the numbers being the variable ID)in the message. Did you actually try installing this version of the plugin or just copy/paste the snippet of code? It should increment to 1.1.3 and update.
Thu Nov 07, 2013 11:21 am
bschollnick2 wrote:
This is a test %%v:isDaylight%% %%v:TagLeaves%% and more
Those should be variable IDs, not variable names.
Thu Nov 07, 2013 11:41 am
Oh. As you can see I have not yet availed myself in using these substitutions yet.
I see that now, and it makes more sense. But doesn't that make it a little harder to debug, since the Integer number makes it a little harder to troubleshoot?
- Benjamin
Thu Nov 07, 2013 12:15 pm
Not really. And it keeps actions from breaking when the user changes the name of a device or variable.
Thu Nov 07, 2013 12:23 pm
Dewster35 offline
Anyone invested in taking feature requests if this plugin goes open source? You know... in case you're bored ;)
If so, having an action to send a message to all GV SMS Plugin Device numbers or to receive an GV SMS Plugin Device message as a trigger would be a great enhancement :)
Thu Nov 07, 2013 4:03 pm
I just heard from Chris and he's given us permission to open source the plugin. Ben, when you're done with your changes email me the plugin.
We have a plan for how to handle open source plugins and I'll get this one ready. More details to come - watch for an announcement post in the Extending Indigo with Plugins and Python forum for details.
Sun Nov 10, 2013 12:35 am
jltnol offline
One feature request would be to add a "Text Contains" option.
Sun Nov 10, 2013 6:47 am
Can you give a little bit more elaboration on this?
- Ben
Sun Nov 10, 2013 10:57 am
jltnol offline
Hey Ben
Yes...
I'm having some computer generated SMS's sent to Indigo... and the text is always going to be slightly different, so BECOMES EQUAL TO always fails. But CONTAINS would succeed.
And the other two options, Becomes Not Equal To, and Has Any Change don't allow for different messages Triggering different things....
Make sense?
Sun Nov 10, 2013 11:04 am
Dewster35 offline
jltnol wrote:
Hey Ben
Yes...
Make sense?
Perhaps an easier concept, I have triggers for changing the thermostat. Heat at 67, 68, 69, 70 etc... so separate triggers for each one of those. If we had a contains "Thermostat", we could trigger a script that would parse for the degrees and then change the set point to whatever number that a message that contains "Thermostat". Reducing the number of triggers to 1 per "Contains" term.
Sun Nov 10, 2013 11:20 am
jltnol offline
Dewster35 wrote:
jltnol wrote:
Hey Ben
Yes...
Make sense?
No doubt this would work as well, but I'm not a script expert by any means.. and I suspect that a lot of Indigo users aren't that script savvy either, but between these two SMS messages:
Notification- xxxy from 12345
and
Notification - xxxy from 98766
If the Google SMS had a Contain option, "Contains xxxy" would trigger what I want to trigger without having to worry about trying to write a script.
Sat Nov 16, 2013 10:36 pm
MrJeffreyGee offline
Is there a way to choose as an option or to change it to archive SMS messages after they've been processed through Indigo; instead of, them being deleted? It's kind of nice that way cause it'll be good for auditing during problems and as a record/log if needed. Plus there's no cost cause Google picks up the tab.
Sun Nov 17, 2013 6:45 am
I will look into this. I'm not sure that the plugin can support this without being redesigned. But I'll take a look.
- Ben
Sun Nov 17, 2013 10:50 am
Ben, don't forget that the source is now hosted on our GitHub account so if you make a change then create your own branch, make the change, sync it with your branch, then issue a pull request. Also, I don't believe you sent me your version with the substitution changes so you'll need to include that change as well if it's ready.
Page 14 of 21 1 ... 11, 12, 13, 14, 15, 16, 17 ... 21
