Google Voice SMS Plugin
Sat Jan 07, 2012 10:58 pm
dmeeker@mac.com offline
Re: Google Voice SMS Plugin for Indigo 5 (SIRI support added
Understood. You are only prompted to enter a phone number two times in the plugin.
1) When you set up the device with your google voice account.
2) When you make a trigger to send a message and you type which number to send the SMS to.
Here is how I have them configured:
The Device:
- Is my Google Voice Number. I created a google voice account JUST for Indigo. This Google voice account only has 1 phone attached to it: my home phone. I only use this account for Indigo.
The Trigger
- Is my my PERSONAL Google voice number. This is a different Google voice number than what Indigo is set up to use. When Indigo sends the message to this number, it goes to my cell phone(s).
I believe that if you are using the same phone to receive messages that is connected to your Google Voice account, there may be issues.
Dave
Tue Jan 17, 2012 10:21 pm
kidney offline
Does anyone have the version that support variables?
Fri Jan 20, 2012 1:34 pm
I would be very interested in the variable-ready version also. The documentation mentions variable substitution options, but they clearly don't work in the version available for download.
Sun Feb 05, 2012 7:39 pm
taankro offline
You can add the variable substitution by modifying the /Library/Application Support/Perceptive Automation/Indigo 5/Plugins/GoogleVoiceSMS.indigoPlugin/Contents/Server Plugin/plugin.py.
Add the bold text to your file.
import re
for match in re.findall(r'%%v:([0-9]+)%%', smsMessage):
smsMessage = smsMessage.replace('%%v:' + match + '%%', indigo.variables[int(match)].value)
def sendSMSMessage (self, action):
                smsDevice = indigo.devices[action.deviceId]
                smsNumber = smsDevice.pluginProps['address']
                smsMessage = action.props["smsMessage"]
                import re
                        indigo.server.log("Sending '"+smsMessage+"' to "+smsNumber)
                        smsDevice.updateStateOnServer(key="lastAction", value="Sending")
                        self.voice.send_sms(smsNumber, smsMessage)
                        smsDevice.updateStateOnServer(key="lastAction", value="Success")
                        indigo.server.log("Message sent successfully.")
                except:
                        smsDevice.updateStateOnServer(key="lastAction", value="Error")
                        indigo.server.log("Unable to send message.")
Save the file the click Plugins -> Google Voice SMS -> Reload
Sun Feb 05, 2012 8:29 pm
Wow. Awesome.
I will give it a shot.
Thank you!
Mon Feb 06, 2012 2:11 pm
Or you can edit it to call the substituteVariable() method described in the plugin.py section of the API docs (it's the last row of the last table)... ;)
Tue Feb 07, 2012 11:37 am
I added the codeblock to the plugin.py script, but alas, the variables are not coming through.
I have a trigger that responds to an incoming SMS. The incoming SMS is "security status".
The response sent back to my device is setup to be:
The front door is %%v:FrontDoorIs%%. The garage door is %%v:The_Garage_Door_Is%%.
Unfortunately, I end up getting that sent back to my phone verbatim, without the variable substitution.
I unloaded and reloaded the plugin. That didn't work.
I restarted indigo. That didn't work either.
Scratching my head....
Any thoughts?
My code looks like:
    # Routines for Sending SMS
                import re
      except:
Tue Feb 07, 2012 12:41 pm
taankro offline
Sorry for the confusion. The code will do a variable substitution on the variable id not the variable name. Should be a number...
Tue Feb 07, 2012 1:08 pm
Ok, So I replaced the variable names I posted before with the VariableID. I assume this is what ID we are dealing with?
I replaced what I had with the following:
The front door is %%v:1965161463%%. The garage door is %%v:214150226%%.
And I get that same exact (unprocessed) string sent via SMS.
Tue Feb 07, 2012 7:23 pm
taankro offline
I sent you an email. But you should check your log after you reload the module. Not sure if your code looks exactly like you posted but if it does you have indented the 3 lines you added one to many times. I suspect your log looks like this when you reload the module if that is the case:
Google Voice SMS Error Error in plugin execution InitializeMain:
<type 'exceptions.IndentationError'>: ('unexpected indent', ('plugin.py', 73, 3, '\t\t\timport re\n'))
Error plugin "Google Voice SMS 1.1.0" failed to initialize
Tue Feb 07, 2012 7:53 pm
I emailed you back also, but for others, thought I'd also post here.
My actual code looks like this:
      import re
I am not getting the indent error.
Instead, I am getting a variable undefined for "re":
File "plugin.py", line 25, in <module>
File "plugin.py", line 74, in Plugin
<type 'exceptions.NameError'>: name 're' is not defined
Tue Feb 07, 2012 8:58 pm
taankro offline
Changed to the substituteVariable() method that Jay referenced from above. Do this instead of the three lines from my earlier posts.
if self.substituteVariable(smsMessage, validateOnly=True):
  smsMessage = self.substituteVariable(smsMessage)
Wed Feb 08, 2012 10:25 am
You only need to call it with validation if you want to do something if there is a validation error - so in your case you can just cal the substitute without validation. It will return a string regardless of any errors.
Also, the return value when validateOnly is True is a tuple - the first item being a boolean and the second (if present) an error string. So you should test the first item in the tuple for true/false.
Wed Feb 08, 2012 5:05 pm
taankro offline
Ok. So I modified mine so that the sms will not be sent if a variable does not exist.
      substituteVariable = self.substituteVariable(smsMessage, validateOnly=True)
      if not substituteVariable[0]:
         indigo.server.log(substituteVariable[1])
         return
      except:
or if you don't mind sending the message with no value substituted you could:
      smsMessage = self.substituteVariable(action.props["smsMessage"])
      except:
Again sorry for the confusion.
Thu Feb 09, 2012 1:49 pm
eme jota ce offline
Feel pretty foolish asking, but where?
No matter how many times I add a new trigger, I don't see a place where I type another number to send the SMS to...I had to add a second SMS plugin device with the number to which I want to send.
Page 4 of 21 1, 2, 3, 4, 5, 6, 7 ... 21
