Can we use this plug in for LE830U series
Posted: Tue May 30, 2017 1:49 pm
I enabled network control and verified that I can telnet to the IP/port, but does not connect to my TV. Does this plugin support LE830U series as it works for my other TV's (different models):
2017-05-30 15:42:31.617 Sharp TV Network Remote Plugin Debug set to True by user
2017-05-30 15:42:35.416 Sharp TV Network Remote Plugin Debug Entering deviceStopComm for Parents TV; ID=1083357202
2017-05-30 15:42:35.419 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:35.421 Sharp TV Network Remote Plugin Debug Initiating shutdown of communications with Parents TV
2017-05-30 15:42:35.422 Sharp TV Network Remote Plugin Debug Shutdown of communications with Parents TV complete
2017-05-30 15:42:35.423 Sharp TV Network Remote Plugin Debug Exiting deviceStopComm for Parents TV
2017-05-30 15:42:37.576 Sharp TV Network Remote Plugin Debug Entering deviceStartComm for Parents TV; ID=1083357202
2017-05-30 15:42:37.578 Sharp TV Network Remote Plugin Debug Read device state config... isConnected: "isConnected"; connectionState: "connectionState"
2017-05-30 15:42:37.579 Sharp TV Network Remote Plugin Debug Establishing connection to 10.0.1.75
2017-05-30 15:42:37.579 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:37.580 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:37.581 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:37.582 Sharp TV Network Remote Plugin Debug Exiting deviceStartComm for Parents TV
2017-05-30 15:42:37.585 Sharp TV Network Remote Plugin Debug Connection established
2017-05-30 15:42:37.592 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:telnetConnectionEOLString
2017-05-30 15:42:37.594 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:telnetConnectionStringEncoding
2017-05-30 15:42:37.596 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:commandReadTimeout
2017-05-30 15:42:37.597 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:updateStatusPollerIntervalProperty
2017-05-30 15:42:37.597 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:emptyQueueReducedWaitCycles
2017-05-30 15:42:37.598 Sharp TV Network Remote Plugin Debug Command queue has 1 command(s) waiting
2017-05-30 15:42:37.599 Sharp TV Network Remote Plugin Debug Create connection command de-queued
2017-05-30 15:42:38.090 Sharp TV Network Remote Plugin Debug Received: Login:
2017-05-30 15:42:38.092 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.093 Sharp TV Network Remote Plugin Debug Found response match: loginPrompt
2017-05-30 15:42:38.094 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.095 Sharp TV Network Remote Plugin Debug Effect execution: Queuing command {writeToTelnetConn}
2017-05-30 15:42:38.096 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.097 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.098 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.099 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.100 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.101 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.102 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.103 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.104 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.105 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.106 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.107 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.108 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.109 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.111 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.112 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.113 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.114 Sharp TV Network Remote Plugin Debug Command queue has 1 command(s) waiting
2017-05-30 15:42:38.115 Sharp TV Network Remote Plugin Debug Sending command: malemous
2017-05-30 15:42:38.116 Sharp TV Network Remote Plugin Debug Write command completed.
2017-05-30 15:42:38.117 Sharp TV Network Remote Plugin Debug Received:
2017-05-30 15:42:38.117 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.118 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.121 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.122 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.123 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.124 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.125 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.126 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.127 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.128 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.129 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.130 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.131 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.132 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.133 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.134 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.135 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.136 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.137 Sharp TV Network Remote Plugin Debug Received w/o Command:
Password:
2017-05-30 15:42:38.137 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.138 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.139 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.140 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.141 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.142 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.143 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.144 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.145 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.146 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.147 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.148 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.149 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.150 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.151 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.154 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:38.156 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
2017-05-30 15:42:43.606 Sharp TV Network Remote Plugin Debug Plugin Command queue has 1 command(s) waiting
2017-05-30 15:42:43.607 Sharp TV Network Remote Plugin Debug Ignoring reconnection command for device 1083357202; new instance detected
2017-05-30 15:42:59.172 Sharp TV Network Remote Plugin Error Connection timed out for device 1083357202
2017-05-30 15:42:59.175 Sharp TV Network Remote Plugin Debug Scheduling reconnection attempt...
2017-05-30 15:42:59.175 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:reconnectAttemptDelay
2017-05-30 15:42:59.176 Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:reconnectAttemptScheme
2017-05-30 15:42:59.177 Sharp TV Network Remote Plugin Debug Reconnection attempt scheduled for 60 seconds
2017-05-30 15:42:59.177 Sharp TV Network Remote Plugin Debug Closing connection to device
2017-05-30 15:43:03.607 Sharp TV Network Remote Plugin Debug Plugin Command queue has 1 command(s) waiting
2017-05-30 15:43:03.608 Sharp TV Network Remote Plugin Debug Plugin command queue not yet ready; requeuing for future execution
Password:
