Re: Error message upon installing 7.4.8
Posted:
Thu Apr 22, 2021 3:55 pm
by RogueProeliator
Yes, I've just verified that as well
My fault, I must never have pushed that to the plugin store after it was validated. Will try to do that shortly.
Adam
Posted:
Wed May 18, 2022 11:12 am
by Different Computers
I *THINK* I'm seeing this same error on my new Roku TCL tv. Granted I've been running the plugin for about 1 day and I'm not entirely sure I have everything set up right, but it seems so.
- Code: Select all
Roku Network Remote Error Error executing effect for device id 1177460091
File "/Library/Application Support/Perceptive Automation/Indigo 2021.2/Plugins/Roku Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkDeviceResponse.py", line 179, in executeEffects
eval(u'rpDevice.' + effect.updateParam + u'(responseObj, rpCommand)')
File "<string>", line 1, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2021.2/Plugins/Roku Network Remote.indigoPlugin/Contents/Server Plugin/rokuNetworkRemoteDevice.py", line 264, in updateDeviceStatusInfo
channelNumber = deviceInfoDoc.find("channel").find("number").text
The plugin does control the TV. I see stuff above about channels and none of my (few, so far) commands do anything with channels.
Posted:
Thu Jun 02, 2022 5:35 pm
Went to GitHub, installed and reinstalled and
Started plugin "Roku Network Remote 2.4.8"
AttributeError: 'NoneType' object has no attribute 'text'
same error.
Posted:
Mon Jul 25, 2022 2:27 pm
Still getting
- Code: Select all
When I turn on debugging I get
- Code: Select all
Roku Network Remote Debug Executing full status update request...
Roku Network Remote Debug Processing GET operation: http|*|/query/device-info
Roku Network Remote Debug Effect execution: Calling function updateDeviceStatusInfo
Roku Network Remote Debug Received device info query response
Roku Network Remote Debug Processing GET operation: http|*|/query/active-app
Roku Network Remote Debug Received active app query response
Roku Network Remote Debug Processing GET operation: http|*|/query/tv-active-channel
Roku Network Remote Debug Received active channel query response
and it *seems* like my TV returns a correct status to Indigo. But still, all that red error message in the log....
Posted:
Wed Aug 03, 2022 7:57 am
Used the "Direct Download" link and the errors seem gone. Notably, though, that download identifies itself as version 2.4.9, not 7.4.9.
Any chance we could get the plugin to receive input status? right now I have to brute force with multiple conditions that check "if app is not X/Y/Z" in order to make Indigo notice that I've changed inputs. Not even sure that's going to work.
Posted:
Wed Aug 02, 2023 3:34 pm
by danieljmorel
I believe this issue has come back with the new release - 2023.7.0. I am receiving the following error for my 2 Roku TV's but not for my other Roku devices (USB Sticks)(There is a whole lot more which I can include if you like)(seems to happen aprox. every minute).:
Aug 2, 2023 at 5:31:02 PM
Roku Network Remote Error An error occurred executing the GET/PUT request (Device: 694568331): HTTPConnectionPool(host='10.0.1.115', port=8060): Max retries exceeded with url: /query/active-app (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x109a38280>, 'Connection to 10.0.1.115 timed out. (connect timeout=None)'))
File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/connection.py", line 174, in _new_conn
conn = connection.create_connection(
File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/util/connection.py", line 95, in create_connection
raise err
File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/util/connection.py", line 85, in create_connection
sock.connect(sa)
TimeoutError: [Errno 60] Operation timed out
During handling of the above exception, another exception occurred:
File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/connectionpool.py", line 703, in urlopen
httplib_response = self._make_request(
File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/connectionpool.py", line 398, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/connection.py", line 239, in request
super(HTTPConnection, self).request(method, url, body=body, headers=headers)
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/http/client.py", line 1282, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/http/client.py", line 1328, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/http/client.py", line 1277, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/http/client.py", line 1037, in _send_output
self.send(msg)
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/http/client.py", line 975, in send
self.connect()
File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/connection.py", line 205, in connect
conn = self._new_conn()
File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/connection.py", line 179, in _new_conn
raise ConnectTimeoutError(
urllib3.exceptions.ConnectTimeoutError: (<urllib3.connection.HTTPConnection object at 0x109a38280>, 'Connection to 10.0.1.115 timed out. (connect timeout=None)')
File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/adapters.py", line 440, in send
resp = conn.urlopen(
File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/connectionpool.py", line 785, in urlopen
retries = retries.increment(
File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/util/retry.py", line 592, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='10.0.1.115', port=8060): Max retries exceeded with url: /query/active-app (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x109a38280>, 'Connection to 10.0.1.115 timed out. (connect timeout=None)'))
Posted:
Wed Aug 23, 2023 9:05 pm
by whmoorejr
danieljmorel wrote:...
I noticed a similar error message soon after the latest release of the plugin.... only on one of my RokuTVs. Oddly (I thought) it was the newest of my Roku TVs. After looking at the TV settings, I found it to be user error. I forgot to change one of the settings.... System -> Power -> Fast TV Start -> On. Maybe that's what's going on?
