Zwave Stick Won’t Mount
Thu Apr 11, 2024 2:33 pm
ckeyes888 offline
Having had some hard drive issues with my 2012 Mac mini running Mojave I tried the migration assistant to a new 2012 mini.
The first issue I had with the new mini was my older Zwave stick not mounting. I tried installing the recommended driver but still no go.
After noticing a number of other issues I’d need to fix as well I decided to temporarily switch back to the old mac only to find the stick wouldn’t mount on that machine either.
Very strange since it was working before I migrated everything to the new one.
Really appreciate any ideas what to try to get it working.
Carl
 RFXCOM Error                    "RFXCOM serial port" serial port open error: [Errno 2] could not open port /dev/cu.usbserial-A12HDS42: [Errno 2] No such file or directory: '/dev/cu.usbserial-A12HDS42'
   RFXCOM Error                    make sure the USB virtual serial port driver (ex: FTDI driver) is installed and correct port is selected
   RFXCOM Error                    serial port could not be opened
Thu Apr 11, 2024 6:11 pm
ckeyes888 offline
Re: Zwave Stick Won’t Mount
Could someone suggest a Zwave stick/interface that works well with Indigo and Mojave?
I suppose it could be just a coincidence my stick died while making the changeover to the new machine.
Carl
Fri Apr 12, 2024 1:01 pm
I would first disconnect all other USB interfaces that are connected to your Mac to make sure that you are selecting the correct Z-Wave interface - you seem to have a bunch. Also, try connecting it directly to a port on your Mac if possible just to make sure that you are getting a good clean connection. You don't say which interface you have, so you may need to install the correct driver and version necessary for Mojave.
The Z-Wave interfaces that are listed on the supported interface list are the ones that we have personally tested and work correctly.
Note in your first post you copy/pasted RFXCOM failures from the log, not the Z-Wave failures...
Fri Apr 12, 2024 1:35 pm
ckeyes888 offline
Thanks. I’ll try disconnecting the others but I know what they are.
I’m using an older Arotec Gen 2 stick.
I seem to remember when it was working the port was something like silabsUSB_ART?
Not seeing anything like that now. Curious what port it typically would be connected to?
Edit: I have installed the VCP driver recommended for Mojave.
Carl
Sat Apr 13, 2024 10:08 am
Carl
And is it showing up correctly? The Z-Stick Gen 2 uses the Silicon Labs driver as described in the Z-Wave docs.
Sat Apr 13, 2024 2:56 pm
CraigM offline
I'm using a Zooz 800 stick $26.95, which requires no driver, on a 2012 Mini and OS Mojave and a USB extension
https://forums.indigodomo.com/viewtopic.php?f=58&t=27868
https://www.thesmartesthouse.com/products/zooz-800-series-z-wave-long-range-usb-stick-zst39
Sat Apr 13, 2024 3:31 pm
ckeyes888 offline
Thanks CraigM, good to know.
Carl
Sat Apr 13, 2024 3:32 pm
ckeyes888 offline
Jay, where to look to see if it’s installed correctly?
Carl
Tue Apr 16, 2024 1:10 am
ckeyes888 offline
Got the Zooz 800 stick to mount but having no luck including/excluding any devices. Odd there aren’t any buttons on it to enter those modes. Tried using the “Start Inclusion mode” selection in Indigo but there’s no feedback that anything is happening and nothing seems to happen if I try to include or exclude.
Appreciate any info on how it’s supposed to work with Indigo.
Carl
Tue Apr 16, 2024 11:04 pm
CraigM offline
Carl
This is my first entry into Z-Wave and all my Zooz 800 devices were included by Indigo very smoothly. I don't know much about Z-Wave (still learning), but I believe you already had a Z-Wave network before on another stick. Could it be your devices needed to be excluded from the old stick first? Just guessing, I'm sure someone more experienced will know what the issue is.
Wed Apr 17, 2024 9:35 am
Craig is correct. You need to exclude your devices before they can be included again. You’ll want to start with the ones that are physically closest to your interface and work your way out.
Wed Apr 17, 2024 11:38 am
CraigM offline
Jay, just for my knowledge, what would be the procedure in this instance if the previous stick was dead/damaged and you couldn't access it to exclude?
Also, I have never heard of excluding starting from the closest to the farthest. Is this rule for excluding all devices (moving to a new stick) or anytime you exclude (same stick)?
Wed Apr 17, 2024 11:49 am
You don’t need the original stick to exclude, any interface can start the exclusion process.
Whenever you are building or rebuilding a Z wave network, it’s always best to start with the closest devices to the interface and work your way out. That will ensure that you’ve got the best possible Z-Wave routes in your devices. You can run an optimization later if you like, but if you do it in that order, then you will likely avoid any range issues when trying to include devices.
The assumption here is that you’ll exclude and then include devices one or two at a time while rebuilding your network.
Wed Apr 17, 2024 11:55 am
dduff617 offline
in my experience, z-wave devices always include a reset procedure (aka "factory reset") and this always entails a (one-sided) exclusion process, meaning that the device forgets its connection to the controller.
so if the controller is not dead, you are better to initiate the exclusion on the controller so that both device and controller will erase the association.
for your specific question though... if controller is dead or corrupted or something, then you need to do the reset process on every affected device before those devices can be added to a replacement controller. or i think it is also possible that a replacement controller can force the device to exclude. either of these are going to require putting hands on the device (by design, since it would be major security issue otherwise).
Wed Apr 17, 2024 3:03 pm
AFAIK, allowing any primary controller to initiate an exclude command with any Z-Wave device is a part of the Z-Wave specification. The way I think about it is, if this weren't the case and your primary controller died, you'd have to throw away all your devices.
