Aeotec ZW095 Energy Monitor - Voltage, Current Measurements
Fri Jul 21, 2023 1:02 pm
outsidenwnc offline
Is there a method to get the voltage, current values from the Aeotec ZW095 Energy Meter? I can see how to change the config parameters for the device to report the data but do not see how one may get the values.
I assume KW, KWH all Indigo supports out of the box.
Currently I have config parameter 101 set to 16131, 111 set to 600. I have left that alone
I have modified 102= 1770254, 112 = 60 to get the other data I want but don't see how that's possible. I can see the values come into Indigo when I turn on z-wave debug but how can I 'grab' that data?
Z-Wave Debug . . requestMeterLevel: 15.024 A (float: 15.024000)
Z-Wave Debug . . requestMeterLevel: 123.992 V (float: 123.992000)
Any tips or guidance appreciated.
Sat Jul 22, 2023 12:25 pm
Re: Aeotec ZW095 Energy Monitor - Voltage, Current Measureme
There isn't a way to do this in Indigo without using a plugin to catch and decode the lower-level incoming Z-Wave commands (which Indigo does provide a callback API for).
An example would be this plugin (forum discussion here). I'm not sure if it will allow you to point to your ZW095 or not, and I'm not sure if it catches voltage and other data or not. However, if it doesn't that plugin still might be a good one to modify to catch the data you need (which would require some Python coding).
Tue Jul 25, 2023 10:41 am
outsidenwnc offline
I'll take a look. Thanks for the tip.
