Match Raw Packet
Sun Apr 16, 2023 9:01 am
michaelcreamer offline
Match Raw Packet
When using the Event "Incoming Command Received from Device" and "Match Raw Packet", is there a way to retrieve the actual packet that was matched inside an action script?
If I could get the actual packet inside the script I could further interrogate the packet.
Michael
Sun Apr 16, 2023 1:48 pm
Re: Match Raw Packet
Hi Michael,
You cannot do it inside of an Action, but you could modify the Example Z-Wave Listener plugin that is in the Indigo Plugin SDK if you need this level of control. It defines a callback that is called when very Z-Wave command packet is received by Indigo, so you can inspect those packets and do whatever logic you need (including executing Indigo action groups, modifying Indigo variable values, etc.).
