I am replacing an existing Honeywell thermostat with a z-wave Honeywell T6 Pro thermostat.
My HVAC system is a HEAT PUMP with a backup gas furnace. On the existing thermostat, I can switch between the modes OFF - AUTO-COOL - HEAT - AUX HEAT. In HEAT mode - the HEAT PUMP is used for heating the house; in instances when the temperature outside is so low that the HEAT PUMP cannot "heat" the house, the gas furnace will come on and supplement.
I can switch to AUX-HEAT and the HEAT PUMP will shutdown and the gas furnace will supply the heat.
I successfully added the Thermostat to my z-wave network. The new z-wave thermostat can switch between the four modes OFF-COOL-HEAT-AUX HEAT.
In INDIGO I can use the DEVICE ACTIONS - THERMOSTAT CONTROLS - CYCLE THROUGH THERMOSTAT MODES to change the mode of the Thermostat. However, I can only cycle through OFF-COOL-HEAT ... I cannot switch to AUX HEAT.
The DEVICE has CUSTOM STATES ... zwaveHvacOperationModeID and zwaveHvacOperationModeName , If I manually change the modes on the thermostat, I can see that the CUSTOM STATES will cycle through all of the modes OFF-AUTO-COOL-HEAT-AUX HEAT.
My Question ...
Is it possible to use PYTHON SCRIPTING to change the thermostat mode to AUX HEAT?
Is there a way of including the AUX HEAT mode from a built-in Indigo function?
From the device details the modes shown are:
hvacOperationMode : 0 (integer)
hvacOperationMode.ui : all off (string)
hvacOperationModeIsAuto : false (bool)
hvacOperationModeIsCool : false (bool)
hvacOperationModeIsHeat : false (bool)
hvacOperationModeIsOff : true (bool)
hvacOperationModeIsProgramAuto : false (bool)
hvacOperationModeIsProgramCool : false (bool)
hvacOperationModeIsProgramHeat : false (bool)
Is there a way of modifying the Properties to include AUX HEAT - for example ....
hvacOperationModeIsAuxHeat :
hvacOperationModeIsProgramAuxHeat:
The CUSTOM STATES show the following when manually changing the modes on the Thermostat.
ID 0 - OFF
ID 1 - HEAT
ID 2 - COOL
ID 3 - AUTO
ID 4 - AUX HEAT
Here are the Device Details ....
Mar 27, 2023 at 9:46:00 PM
Script address : 182
batteryLevel : 95
buttonGroupCount : 0
configured : True
coolIsOn : False
coolSetpoint : 72.0
dehumidifierIsOn : False
description :
deviceTypeId : zwThermostatType
displayStateId : temperatureInputsAll
displayStateImageSel : HvacOff
displayStateValRaw : 67
displayStateValUi : 67
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
fanIsOn : False
fanMode : Auto
folderId : 268548652
com.perceptiveautomation.indigoplugin.zwave : (dict)
NumHumidityInputs : 1 (integer)
ShowCoolHeatEquipmentStateUI : true (bool)
SupportsBatteryLevel : true (bool)
TempUnits : 2 (integer)
address : 182 (integer)
indigoObjVersion : 10 (integer)
userEnergyPollingEnabled : false (bool)
userPollInterval : 0 (integer)
userPollingEnabled : false (bool)
userWakeInterval : 60 (integer)
version : 1.03 (string)
zwAppVersMajor : 1 (integer)
zwAppVersMinor : 3 (integer)
zwAssociationsMap : (dict)
g1 : (list)
Item : 1 (integer)
zwAssociationsMapStr : 1:[1] (string)
zwClassCmdBase : 64 (integer)
zwClassCmdMap : (dict)
c108 : 1 (integer)
c112 : 1 (integer)
c113 : 1 (integer)
c114 : 1 (integer)
c115 : 1 (integer)
c128 : 1 (integer)
c129 : 1 (integer)
c133 : 1 (integer)
c134 : 1 (integer)
c159 : 1 (integer)
c32 : 1 (integer)
c49 : 5 (integer)
c64 : 1 (integer)
c66 : 1 (integer)
c67 : 1 (integer)
c68 : 1 (integer)
c69 : 1 (integer)
c85 : 1 (integer)
c89 : 1 (integer)
c90 : 1 (integer)
c94 : 1 (integer)
zwClassCmdMapStr : 20v1 40v1 43v1 72v1 86v1 5Ev1 85v1 59v1 31v5 80v1 81v1 70v1 5Av1 71v1 73v1 9Fv1 44v1 45v1 42v1 6Cv1 55v1 (string)
zwClassIds : (list)
Item : 4 (integer)
Item : 8 (integer)
Item : 6 (integer)
zwClassInstanceCountMap : (dict)
zwClassInstanceCountMapStr : - none - (string)
zwClassName : General Thermostat (v2) (string)
zwConfigVals : (dict)
zwConfigValsStr : - none - (string)
zwDevSubIndex : 0 (integer)
zwEncryptClassCmdMap : (dict)
zwEncryptClassCmdMapStr : - none - (string)
zwEncryptionStatusStr : Not Supported (string)
zwEndpointClassMap : (dict)
zwEndpointClassMapStr : - none - (string)
zwEndpointDevTypeMap : (dict)
zwEndpointDevTypeMapStr : - none - (string)
zwFeatureListStr : routing, battery, beaming, frequentWaking (string)
zwLibType : 6 (integer)
zwManufactureId : 57 (integer)
zwManufactureName : Honeywell (string)
zwModelDefnVers : 1 (integer)
zwModelId : 1114120 (integer)
zwModelName : Thermostat (TH6320ZW2003) (string)
zwNodeNeighbors : (list)
Item : 1 (integer)
Item : 3 (integer)
Item : 7 (integer)
Item : 8 (integer)
Item : 9 (integer)
Item : 19 (integer)
Item : 23 (integer)
Item : 24 (integer)
Item : 27 (integer)
Item : 28 (integer)
Item : 29 (integer)
Item : 33 (integer)
Item : 37 (integer)
Item : 38 (integer)
Item : 39 (integer)
Item : 40 (integer)
Item : 42 (integer)
Item : 44 (integer)
Item : 45 (integer)
Item : 46 (integer)
Item : 48 (integer)
Item : 50 (integer)
Item : 52 (integer)
Item : 54 (integer)
Item : 55 (integer)
Item : 59 (integer)
Item : 63 (integer)
Item : 65 (integer)
Item : 66 (integer)
Item : 67 (integer)
Item : 68 (integer)
Item : 69 (integer)
Item : 76 (integer)
Item : 79 (integer)
Item : 80 (integer)
Item : 86 (integer)
Item : 87 (integer)
Item : 89 (integer)
Item : 90 (integer)
Item : 91 (integer)
Item : 94 (integer)
Item : 103 (integer)
Item : 109 (integer)
Item : 118 (integer)
Item : 119 (integer)
Item : 120 (integer)
Item : 121 (integer)
Item : 122 (integer)
Item : 125 (integer)
Item : 132 (integer)
Item : 140 (integer)
Item : 154 (integer)
Item : 155 (integer)
Item : 157 (integer)
Item : 159 (integer)
Item : 163 (integer)
Item : 165 (integer)
Item : 169 (integer)
Item : 170 (integer)
Item : 171 (integer)
Item : 172 (integer)
Item : 173 (integer)
Item : 174 (integer)
Item : 175 (integer)
Item : 176 (integer)
Item : 178 (integer)
zwNodeNeighborsStr : 1, 3, 7, 8, 9, 19, 23, 24, 27, 28, 29, 33, 37, 38, 39, 40, 42, 44, 45, 46, 48, 50, 52, 54, 55, 59, 63, 65, 66, 67, 68, 69, 76, 79, 80, 86, 87, 89, 90, 91, 94, 103, 109, 118, 119, 120, 121, 122, 125, 132, 140, 154, 155, 157, 159, 163, 165, 169, 170, 171, 172, 173, 174, 175, 176, 178 (string)
zwProtoVersMajor : 4 (integer)
zwProtoVersMinor : 61 (integer)
zwShowDumpDevToLog : true (bool)
zwShowEnergyPollingUI : false (bool)
zwShowMainUI : true (bool)
zwShowManualModifyConfigParmUI : true (bool)
zwShowPollingUI : false (bool)
zwShowSubmitModelInfoUI : false (bool)
zwShowWakeIntervalUI : false (bool)
zwWakeInterval : 0 (integer)
heatIsOn : False
heatSetpoint : 67.0
humidities : [42.0]
humiditySensorCount : 1
hvacMode : Off
lastChanged : 2023-03-27 16:46:05
lastSuccessfulComm : 2023-03-27 16:46:05
model : Thermostat (TH6320ZW2003)
name : NORTH THERMOSTAT
ownerProps : com.perceptiveautomation.indigoplugin.zwave : (dict)
g1 : (list)
Item : 1 (integer)
c108 : 1 (integer)
c112 : 1 (integer)
c113 : 1 (integer)
c114 : 1 (integer)
c115 : 1 (integer)
c128 : 1 (integer)
c129 : 1 (integer)
c133 : 1 (integer)
c134 : 1 (integer)
c159 : 1 (integer)
c32 : 1 (integer)
c49 : 5 (integer)
c64 : 1 (integer)
c66 : 1 (integer)
c67 : 1 (integer)
c68 : 1 (integer)
c69 : 1 (integer)
c85 : 1 (integer)
c89 : 1 (integer)
c90 : 1 (integer)
c94 : 1 (integer)
zwClassIds : (list)
Item : 4 (integer)
Item : 8 (integer)
Item : 6 (integer)
Item : 1 (integer)
Item : 3 (integer)
Item : 7 (integer)
Item : 8 (integer)
Item : 9 (integer)
Item : 19 (integer)
Item : 23 (integer)
Item : 24 (integer)
Item : 27 (integer)
Item : 28 (integer)
Item : 29 (integer)
Item : 33 (integer)
Item : 37 (integer)
Item : 38 (integer)
Item : 39 (integer)
Item : 40 (integer)
Item : 42 (integer)
Item : 44 (integer)
Item : 45 (integer)
Item : 46 (integer)
Item : 48 (integer)
Item : 50 (integer)
Item : 52 (integer)
Item : 54 (integer)
Item : 55 (integer)
Item : 59 (integer)
Item : 63 (integer)
Item : 65 (integer)
Item : 66 (integer)
Item : 67 (integer)
Item : 68 (integer)
Item : 69 (integer)
Item : 76 (integer)
Item : 79 (integer)
Item : 80 (integer)
Item : 86 (integer)
Item : 87 (integer)
Item : 89 (integer)
Item : 90 (integer)
Item : 91 (integer)
Item : 94 (integer)
pluginId : com.perceptiveautomation.indigoplugin.zwave
protocol : ZWave
remoteDisplay : True
states : States : (dict)
batteryLevel : 95 (integer)
batteryLevel.ui : 95% (string)
humidityInput1 : 42 (real)
humidityInput1.ui : 42.0% (string)
humidityInputsAll : 42 (string)
hvacCoolerIsOn : off (on/off bool)
hvacDehumidifierIsOn : off (on/off bool)
hvacFanIsOn : off (on/off bool)
hvacFanMode : 0 (integer)
hvacFanMode.ui : auto on (string)
hvacFanModeIsAlwaysOn : false (bool)
hvacFanModeIsAuto : true (bool)
hvacHeaterIsOn : off (on/off bool)
hvacHumidifierIsOn : off (on/off bool)
setpointCool : 72 (real)
setpointCool.ui : 72.0 °F (string)
setpointHeat : 67 (real)
setpointHeat.ui : 67.0 °F (string)
temperatureInput1 : 67 (real)
temperatureInput1.ui : 67.0 °F (string)
temperatureInputsAll : 67 (string)
zwaveHvacOperationModeID : 0 (integer)
zwaveHvacOperationModeName : off (string)
subModel :
subType :
supportsAllOff : False
supportsCoolSetpoint : True
supportsHeatSetpoint : True
supportsHvacFanMode : True
supportsHvacOperationMode : True
supportsOnState : False
supportsStatusRequest : True
temperatureSensorCount : 1
temperatures : [67.0]
version : 1.03
