Does anyone know if ZOOZ Z-WAVE PLUS 700 SERIES TITAN WATER VALVE ACTUATOR ZAC36 will work properly with Indigo?
I didn't see it listed on the compatible devices page...
Reverse open / close commands and reports:
- Use this method if your hub displays the open/close commands in reverse to the actual operation and doesn't give you access to change the advanced settings in the interface (if you have access to advanced settings, follow the guidelines for parameter 17 instead)
- Hold the Z-Wave button until 4 beeps sound, release the button, then immediately after, tap the button 3 times (it will flash green and beep once each time you touch it)
- Flashing green and 2 beeps to indicate successful setting change
- Back to standby mode (yellow flashing when not included to Z-Wave hub or pulsing green when included to Z-Wave hub)
