I added 4 Zlink in Wall Dimmers (ZL-WD-100) to Indigo this morning. Two of the 4 inclusions reported an error. The 2 dimmers that reported an error when locally controlled (on/off/dim) do not report their status to Indido. This is the problem. What can I do to diagnose the issue. I have included the relevant text from the Event Log.
Thanks.
This is the log for the first. No errors. Dimmer is in a single gang box.
Nov 6, 2022 at 8:31:56 AM
Z-Wave Syncing - started for "022 - Dimmable Power Switch"
Z-Wave Syncing - retrieved module neighbors list: 3, 4, 10, 11, 13, 14, 16, 19, 21
Z-Wave Syncing - assigning return route to "022 - Dimmable Power Switch"
Z-Wave Syncing - retrieved manufacture and model names: ZLINK - 0315, Dimmer Switch (WD100) - 44473034
Z-Wave Syncing - retrieved protocol version 6.01, app version 50.06
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01, base 26)
Z-Wave Syncing - retrieved command classes: 20v1 26v4 27v1 5Ev1 86v1 72v1 5Av1 85v1 59v1 55v1 73v1 70v1 2Cv1 2Bv1 5Bv1 7Av1 9Fv1 6Cv1
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - added group 1 association to interface
Z-Wave Syncing - retrieved parameter 4 "Reverse switch controls" is false
Z-Wave Syncing - retrieved parameter 9 "Local dim delta" is 1
Z-Wave Syncing - retrieved parameter 10 "Local dim timer" is 3 * 10 milliseconds
Z-Wave Syncing - retrieved parameter 7 "On/Off dim delta" is 1
Z-Wave Syncing - retrieved parameter 8 "On/Off dim timer" is 3 * 10 milliseconds
Z-Wave Syncing - created device "022 - Dimmer Switch (WD100)"
Z-Wave Syncing - complete
This is the second. No errors reported. This dimmer is in a 3 gang wall box with the 2 dimmers (024, 025) below that reported errors.
Nov 6, 2022 at 8:38:42 AM
Z-Wave started controller inclusion mode
Z-Wave controller included module: 023 - Dimmable Power Switch
Z-Wave stopped controller inclusion mode
Z-Wave Syncing - started for "023 - Dimmable Power Switch"
Z-Wave Syncing - retrieved module neighbors list: 3, 4, 10, 11, 13, 14, 15, 16, 19, 21, 22
Z-Wave Syncing - assigning return route to "023 - Dimmable Power Switch"
Z-Wave Syncing - created device "023 - Dimmer Switch (WD100)"
This is the third. It reported "failed to assign return route". It is located in a 3 gang wall box with the dimmer above (023) and the dimmer below (025).
Nov 6, 2022 at 8:44:14 AM
Z-Wave controller included module: 024 - Dimmable Power Switch
Z-Wave Syncing - started for "024 - Dimmable Power Switch"
Z-Wave Syncing - assigning return route to "024 - Dimmable Power Switch"
Z-Wave Error Syncing - failed to assign return route
Z-Wave Syncing - created device "024 - Dimmer Switch (WD100)"
This is the fourth. It reported "failed to assign return route". It is located in a 3 gang wall box with the 2 (023, 024) dimmers above.
Nov 6, 2022 at 8:47:40 AM
Z-Wave controller included module: 025 - Dimmable Power Switch
Z-Wave Syncing - started for "025 - Dimmable Power Switch"
Z-Wave Syncing - assigning return route to "025 - Dimmable Power Switch"
Z-Wave Syncing - created device "025 - Dimmer Switch (WD100)"
