Hi all,
I'm beginning to reinstall my z-wave devices after a move to a new home. I just installed a wall switch (GE ZW4001 relay switch 45609) to control a lamp via an appliance module. The switch works, but there is a 3 second delay before the light comes on which I never had in my earlier installation. To troubleshoot, I swapped out the switch for another of the same model and got the same result. I then swapped out the appliance module for a GE Outdoor Appliance Module (also never had issues) and still got the same result. I've also re-optimized the network and that had no effect.
For context, this is a bedroom directly above the Indigo MacMini (2012/Catalina/SSD/16gig ram) with only a wood floor in-between. The Zstick Gen5+ is plugged directly into the USB port on the MacMini and is unobstructed. (also tried changing USB ports to no avail).
What's really odd (at least to me) is I changed the triggering device to a door sensor and to a motion sensor triggered from right next to the switch location and the light switched on immediately with both of those sensors.
I'm out of ideas! Any help would be greatly appreciated!
TIA,
Jim
