Zooz USB 700 Series Z-Wave Plus S2 Stick ZST10 700
Sun Sep 04, 2022 5:39 pm
aldera offline
Is anyone using the Zooz USB stick with Indigo? I know it doesn't show as supported hardware on Indigo but the Zooz website mentions Indigo as one of the software options.
Also, if I were to switch USB sticks, do I have to start from scratch and exclude all my devices on the old stick and then include them on the Zooz? Thanks.
Ralph
Mon Sep 05, 2022 12:19 pm
Re: Zooz USB 700 Series Z-Wave Plus S2 Stick ZST10 700
Hi Ralph,
We added support for the Zooz S2 Stick (ZST10) back in Indigo v2021.1.1. You will need to exclude and re-include all of the modules into the new controller. You might also need to select the new device address (node ID) in Indigo's device dialogs for the modules after they are re-included (unless you happen to get them included in exactly the same order which will hopefully give them the same addresses).
Note you can use the newer controller to do both the exclude and then re-include. That is, you don't have to use the original controller to have the modules exclude themselves; the newer controller can do it as well.
Mon Sep 05, 2022 5:45 pm
aldera offline
Okay. Sounds like a lot of work, but doable.
Thanks.
Ralph
