DaveL17 wrote:re-add it through the normal inclusion process. Then, just update the Indigo device definition to point to the new device ID.
- Select DEVICES in the Main Window outline view or select one of the sub-folders.
- Find the device in the device table and double click it (or select it and click the Edit… button).
- Click the Define and Sync… button.
- Follow the instructions on the dialog to use your interface to include the device into your network if you haven't already.
- Select the new device in the Sync using node popup
- Click on the “Sync” button.
- When the Synchronize Z-Wave Device dialog disappears, just close the Edit Device dialog.
