I have a couple of Qubino Flush 1D devices, one for my garage door, one for my front door. I can get the devices to work fine in terms of turning on the output and a timer to default turn them off again without any issues. Everything is running in 24VDC. The problem I have is I have read switches on each door which are wired to the I2 switch inputs on the devices, they're negative switching (which is the 'live' terminal). I've configured the parameters on the switches ok and I can see in the z-wave debug log that open and close of the door is indeed causing an event changing the value from 0 to 255 and back again but I can't seem to see this status in Indigo anywhere other than the debug log, for example the 'on state' in the device details remains 'off' regardless of whether the door is open or closed.
I'm wondering if I'm not using the switch correctly in Indigo.
From the log:
- Code: Select all
23 Jul 2022 at 9:04:26 pm
Z-Wave Debug RCVD requestBinarySensorStatus: 01 09 00 04 00 23 03 30 03 FF 1E
Z-Wave Debug . . requestBinarySensorStatus: node 035, endpoint None, value 255
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 23 09 71 05 00 00 00 FF 07 08 00 5A
Z-Wave Debug . . requestAlarmSensorStatus: node 035, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 8, classSubKeyExt 7100000708
23 Jul 2022 at 9:05:16 pm
Z-Wave Debug RCVD requestBinarySensorStatus: 01 09 00 04 00 23 03 30 03 00 E1
Z-Wave Debug . . requestBinarySensorStatus: node 035, endpoint None, value 0
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 23 09 71 05 00 00 00 FF 07 00 00 52
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 0, classSubKeyExt 7100000700
Screenshot of UI attached.
