Fibaro Dimmer 2 FGD-212
Tue Jun 07, 2022 6:55 am
Turribeach offline
One of my Fibaro Dimmers died and got a new one from Amazon UK and it's not being fully recognised by Indigo. The Fibaro model is Fibaro Dimmer 2 FGD-212 ZW5 v3.5. Here are the Device Details:
Indigo Z-Wave Version: 2022.2.1
Node ID: 82
Model: Dimmable Power Switch
Model ID: 01021001
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 4.24
Application Version: 3.05
Model Definition Version: 0
Library Type: 3
Class Name: Dimmable Power Switch
Class Hierarchy: 04 : 11 : 01
Command Class Base: 26
Command Versions: 20v1 26v3 27v1 5Ev1 86v1 72v1 5Av1 59v1 85v1 73v1 98v1 7Av1 56v1 70v1 31v4 32v3 8Ev1 60v4 75v1 71v1 22v1
Multi-Endpoint Types: 1:(11 : 01), 2:(11 : 01)
Multi-Endpoint Classes: 1:[5E 20 86 26 85 59 8E 32 31 71], 2:[5E 20 86 26 85 59 8E]
Features: routing, beaming, security, energyMeter, powerMeter
Neighbors: 1, 5, 15, 18, 28, 29, 31, 35, 39, 40, 45, 50, 52, 58, 60, 61, 64, 68, 69, 70, 71, 72, 73, 77, 78, 81
Associations: 1:[1] 2:[] 3:[] 4:[] 5:[]
Config Values: - none -
I tried "Submit to Indigo" but I got an error:
   Z-Wave Error                    Error in plugin execution UiAction:
  File "plugin.py", line 446, in submit_dev_profile
type: module 'urllib' has no attribute 'parse'
Christian
Tue Jun 07, 2022 8:39 am
Turribeach offline
Re: Fibaro Dimmer 2 FGD-212
Forgot to say the dimmer sync'ed without errors and is working fine. Obviously I had to configure it using the Modify Configuration Parameter but other than that it's working fine
Sat Jun 11, 2022 4:56 pm
Hi Christian,
Thanks for the reports. We'll get both the device submission bug fixed and your model ID for the FGD-212 added to the next release of Indigo.
Wed Jun 29, 2022 11:56 am
Indigo 2022.1.2 is now available and included beta (untested) support for the your FGD-212. Please let us know if it works correctly for you.
Wed Jun 29, 2022 2:04 pm
Turribeach offline
Thanks Matt, I re-sync'ed the device and it's fully recognised now.
Users browsing this forum: No registered users and 20 guests
