Syncing a Zooz RGBW controller ZEN31
Fri May 20, 2022 8:08 am
rehafer offline
I recently added a Zooz ZEN31 to my setup. I included it with the Zooz Z stick easy enough, but I can’t get to sync to new device.
I’m Indigo 2022.1 on macOS 12.4 and get this lengthy error:
Error in plugin execution:
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/serialinterface.py", line 547, in start_comm_thread
self.process_comm_thread()
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/serialinterface.py", line 731, in process_comm_thread
self.process_queue_in_packet(packet) # Subclass is required to define.
File "zwaveinterface.py", line 2882, in process_queue_in_packet
File "zwaveinterface.py", line 2854, in _processFuncCall
File "zwaveinterface.py", line 2920, in _processCommandReply
File "zwaveinterface.py", line 2903, in _processFuncTriggersAndBroadcast
File "zwaveinterface.py", line 2852, in _processFuncCall
File "zwavecmd_security.py", line 260, in _processEncryptedPacket
File "zwavecmd_multiinstanceinfo.py", line 184, in _processMultiEndPointInfo
File "zwavecmd_multiinstanceinfo.py", line 53, in _requestNextEndPoint
File "zwavecmd_multiinstanceinfo.py", line 49, in _getNextEndPoint
AttributeError: 'range' object has no attribute 'pop'
Z-Wave Error exc type is <class 'AttributeError'>
Z-Wave Error restarting serial connection in 5.0 seconds
Interface Failure lost connection with interface
Z-Wave Error Syncing - failed
Z-Wave Error Timeout waiting for "015 - Mulitlevel Switch". Module might be asleep, or is unreachable.
Z-Wave connected to Z-Stick 7 (ZWA010) interface on /dev/cu.usbserial-0001 (firmware 7.17, minimum SDK 7.00.00)
Can anyone give me a cue how I’m messing up?
Fri May 20, 2022 9:07 am
Re: Syncing a Zooz RGBW controller ZEN31
This is a known issue and will be fixed in the next bug fix release (2022.1.1).
Fri May 20, 2022 9:22 am
rehafer offline
Glad to know it wasn’t just me, thanks.
Fri May 20, 2022 2:18 pm
Frakke offline
Hi Jay, any idea when this will be? I can't add an important piece (Fibaro smart implant) at this moment..?
Fri May 20, 2022 4:35 pm
No firm ETA, but possibly next week. Thanks for the patience.
Thu May 26, 2022 10:48 am
Indigo 2022.1.1 is now available and should fix this Z-Wave bug.
Mon May 30, 2022 5:26 am
Frakke offline
That worked for me, thanks!
