GE Smart Motion Switch (26931) Failing After 2022.2 Upgrade
Mon Apr 18, 2022 5:29 pm
automaton offline
After an upgrade from Indigo 7.3 to 2022.2, When doing a "Define and Sync" on a previously existing GE Zwave device "Smart Motion Switch (26931)", the following error occurs:
Z-Wave Syncing - started for "2FL Mstr Bedroom Closet Light"
Z-Wave Syncing - retrieved module neighbors list: 1, 2, 3, 8, 14, 15, 17
Z-Wave Syncing - assigning return route to "016 - 2FL Mstr Bedroom Closet Light"
Z-Wave Error Error in plugin execution:
File "/Library/Application Support/Perceptive Automation/Indigo 2021.2/IndigoPluginHost.app/Contents/Resources/PlugIns/serialinterface.py", line 517, in startCommThread
self.processCommThread()
File "/Library/Application Support/Perceptive Automation/Indigo 2021.2/IndigoPluginHost.app/Contents/Resources/PlugIns/serialinterface.py", line 691, in processCommThread
self.processQueueInPacket(packet) # Subclass is required to define.
File "zwaveinterface.py", line 2883, in processQueueInPacket
File "zwaveinterface.py", line 2855, in _processFuncCall
File "zwaveinterface.py", line 2921, in _processCommandReply
File "zwaveinterface.py", line 2904, in _processFuncTriggersAndBroadcast
File "zwaveinterface.py", line 2853, in _processFuncCall
File "zwavecmd_manufactureinfo.py", line 79, in _processManufactureInfo
File "zwavenode.py", line 607, in _updateModelInfoFromIDs
AttributeError: 'module' object has no attribute 'kModelDefinition'
Z-Wave Error exc type is <type 'exceptions.AttributeError'>
Z-Wave Error restarting serial connection in 5.0 seconds
After the Plug in reloads, this error is posted:
Z-Wave Error failed to get module 016 info from controller ('module' object has no attribute 'kModelDefinition')
Z-Wave Error Error trying to communicate with "016 - 2FL Mstr Bedroom Closet Light".
I deleted the device from Indigo and then excluded it from the Zwave controller. After including the device successfully, I get the following error when trying to define and sync a new indigo device using this Zwave device.
Z-Wave Error Error trying to communicate with "018 - Relay Power Switch".
Device Details:
Indigo Z-Wave Version: 2021.2.0
Node ID: 16
Model: Smart Motion Switch (26931)
Model ID: 494D3032
Manufacturer: General Electric
Manufacturer ID: 0063
Protocol Version: 4.54
Application Version: 5.39
Model Definition Version: 1
Library Type: 3
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 85v1 86v1 8Ev1 56v1 59v1 5Av1 5Ev1 60v4 25v1 27v1 2Bv1 2Cv1 70v1 71v1 72v1 73v1 7Av1
Multi-Endpoint Types: 1:(10 : 01), 2:(07 : 01)
Multi-Endpoint Classes: 1:[5E 59 25], 2:[5E 59 71]
Features: routing, beaming
Neighbors: 1, 2, 3, 8, 14, 15
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
Mon Apr 18, 2022 8:08 pm
Re: GE Smart Motion Switch (26931) Failing After 2022.2 Upg
I believe you mean Indigo 2021.2.1 (2022.1 is not yet available).
This is a known bug that will be fixed in the upcoming release. We don't have an ETA yet – appreciate your patience.
Mon Apr 18, 2022 8:14 pm
automaton offline
Thanks Matt, sorry I missed the bug in the forum.
Tue May 10, 2022 3:28 pm
Indigo 2022.1.0 is now available and should fix this problem.
Sun Sep 04, 2022 4:37 pm
automaton offline
Matt,
Has this bug been fixed or scheduled?
Sun Sep 04, 2022 6:29 pm
Check the post just above yours...
