Z-Wave Device Sync issues
Thu Apr 14, 2022 3:00 pm
Fxguy offline
Finally got around to pairing my Relay Switch from Zooz (ZEN71). The only problem is when I go to create a new device and sync, I get the error that it timed out or is off.
My event log looks like this:
Apr 14, 2022 at 3:54:05 PM
Z-Wave Syncing - started for "008 - Relay Power Switch"
Z-Wave Syncing - retrieved module neighbors list: 4, 7
Z-Wave Syncing - assigning return route to "008 - Relay Power Switch"
Z-Wave Error Syncing - failed to assign return route
Z-Wave Error Timeout waiting for "008 - Relay Power Switch". Module might be asleep, or is unreachable.
Z-Wave Syncing - started for "009 - Relay Power Switch"
Z-Wave Syncing - assigning return route to "009 - Relay Power Switch"
Z-Wave Error Timeout waiting for "009 - Relay Power Switch". Module might be asleep, or is unreachable.
Z-Wave started controller inclusion mode
Z-Wave stopping controller inclusion mode
Z-Wave stopped controller inclusion mode
Any ideas on how I can get it to sync?
Sat Apr 16, 2022 7:24 am
Re: Z-Wave Device Sync issues
There could be a couple issues at work.
There could be issues with the distance between the switch and the Z-Stick. With respect to distance, walls matter and a 6 inch wall could be a foot thick depending on the angle that the signal passes through the wall. More walls, more trouble. Is it possible to move the Indigo server and Z-Stick closer to the switch?
There could be issues with the number of hops between the Z-Stick and the switch. There are a maximum number of hops allowed; I don't recall the exact number off-hand, but it's 4 or 5 I think.
The switch should be able to sync at any time since it's a mains-powered device, but try switching the load manually and try to sync quickly afterwards.
Sometimes devices don't include properly and may require a re-include. First, try to EXCLUDE the device and then try to re-include it.
Sometimes, you can come across a dud, too. Has happened to me before (to be fair, not with Zooz--I don't have any of those in my system).
Sat Apr 16, 2022 5:20 pm
Hops is max 6 devices including the Zstick and the device in question.
1(Stick) > 2 > 3 > 4 > 5 > 6(Device)
Sat Apr 23, 2022 7:17 pm
Fxguy offline
As far as number of hops, I only have a Z-Wave Thermostat, Z-Wave wall plug and Z-Wave Door Lock, so I dont think its number of hops being the issue. I took my Z-Wave stick right next to the device and included it to get it to show up in Indigo in the first place.
Sun Apr 24, 2022 3:04 pm
That might be the problem. Exclude it, then reinclude it from Indigo while it's plugged into your Mac.
Sun Oct 16, 2022 2:09 pm
pfams12 offline
I'm having an issue getting a new UltraPro In-wall z-wave smart dimmer to sync. I've tried troubleshooting using other posts on the forum. Here is the logout put when attempting to sync the device (with z-wave debug enabled):
Oct 16, 2022 at 3:01:12 PM
   Z-Wave Debug                    intiatingSyncUI (timeout in 1500 seconds)
   Z-Wave                          Syncing - started for "013 - Dimmable Power Switch"
   Z-Wave Debug                    SENT getNodeNeighbors: 01 06 00 80 0D 01 01 74
   Z-Wave Debug                    RCVD getNodeNeighbors: 01 20 01 80 19 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4D (no inbound callback)
   Z-Wave Debug                    . .  getNodeNeighbors: nodeId 013, neighbors: 1, 4, 5, 10, 12
   Z-Wave                          Syncing - retrieved module neighbors list: 1, 4, 5, 10, 12
   Z-Wave                          Syncing - assigning return route to "013 - Dimmable Power Switch"
   Z-Wave Debug                    SENT assignReturnRoute: 01 05 00 46 0D 01 B0
   Z-Wave Debug                    RCVD assignReturnRoute: 01 04 01 46 01 BD (no inbound callback)
   Z-Wave Debug                    RCVD assignReturnRoute: 01 05 00 46 01 01 BC
   Z-Wave Debug                    . .  assignReturnRoute: node 013, success 0
   Z-Wave Debug                    SENT requestNodeInfo: 01 06 00 60 0D 24 F3 43
   Z-Wave Debug                    RCVD requestNodeInfo: 01 06 00 49 81 00 00 31
   Z-Wave Debug                    RCVD requestNodeInfo: failed (module asleep or doesn't support command)
   Z-Wave Error                    No response from "013 - Dimmable Power Switch". Module might be asleep, or is unreachable.
Oct 16, 2022 at 3:01:46 PM
   Z-Wave Debug                    terminatingSyncUI
Thanks - Paul
Sun Oct 16, 2022 2:22 pm
pfams12 offline
Was able to sort the issue by removing failed devices and start the sequence over (I also changed the position of the z-wave stick, not sure if this was impactful but worth mentioning)
Oct 16, 2022 at 3:19:08 PM
   Z-Wave Debug                    SENT requestHasNodeFailed: 01 04 00 62 03 9A
   Z-Wave Debug                    RCVD requestHasNodeFailed: 01 04 01 62 01 99 (no inbound callback)
   Z-Wave Debug                    SENT removeFailedNode: 01 04 00 61 03 99
   Z-Wave Debug                    RCVD removeFailedNode: 01 04 01 61 00 9B (no inbound callback)
   Z-Wave                          removing from controller failed module "003 - Relay Power Switch"
   Z-Wave Debug                    RCVD removeFailedNode: 01 05 00 61 02 01 98
   Z-Wave Debug                    . .  removeFailedNode: node 003, status 2
   Z-Wave Debug                    SENT requestHasNodeFailed: 01 04 00 62 04 9D
   Z-Wave Debug                    RCVD requestHasNodeFailed: 01 04 01 62 00 98 (no inbound callback)
   Z-Wave Debug                    SENT requestHasNodeFailed: 01 04 00 62 05 9C
   Z-Wave Debug                    SENT requestHasNodeFailed: 01 04 00 62 0A 93
   Z-Wave Debug                    SENT requestHasNodeFailed: 01 04 00 62 0C 95
   Z-Wave Debug                    SENT requestHasNodeFailed: 01 04 00 62 0D 94
   Z-Wave Debug                    SENT removeFailedNode: 01 04 00 61 0D 97
   Z-Wave                          removing from controller failed module "013 - Dimmable Power Switch"
   Z-Wave Debug                    . .  removeFailedNode: node 013, status 2
   Z-Wave                          reloading module information from controller
   Z-Wave Debug                    stopping node healing thread
   Z-Wave Debug                    stopping node status polling thread
   Z-Wave Debug                    stopped zwave packet parser thread
   Z-Wave                          connection reset requested
   Z-Wave Debug                    starting serial connection loop
   Z-Wave Debug                    starting zwave packet parser thread
   Z-Wave Debug                    SENT getVersion: 01 03 00 15 E9
   Z-Wave Debug                    RCVD getVersion: 01 10 01 15 5A 2D 57 61 76 65 20 32 2E 37 38 00 01 9B (no inbound callback)
   Z-Wave Debug                    . .  getVersion: Z-Wave 2.78 static controller
   Z-Wave Debug                    SENT getHomeID: 01 03 00 20 DC
   Z-Wave Debug                    RCVD getHomeID: 01 08 01 20 01 84 CD AF 01 30 (no inbound callback)
   Z-Wave Debug                    . .  getHomeID: 0184CDAF, nodeID: 001
   Z-Wave Debug                    SENT getInterfaceFeatures: 01 03 00 05 F9
   Z-Wave Debug                    RCVD getInterfaceFeatures: 01 04 01 05 18 E7 (no inbound callback)
   Z-Wave Debug                    . .  getInterfaceFeatures: 18
   Z-Wave Debug                    SENT getInterfaceApiCapabilities: 01 03 00 07 FB
   Z-Wave Debug                    RCVD getInterfaceApiCapabilities: 01 2B 01 07 03 07 00 86 00 02 00 01 FE 80 FE 88 0F 00 00 00 FB 97 7F 82 07 00 00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C2 (no inbound callback)
   Z-Wave Debug                    . .  getInterfaceApiCapabilities: supportedFuncIDs: 02 03 04 05 06 07 08 10 12 13 14 15 16 17 18 1C 20 21 22 23 24 41 42 44 45 46 47 48 49 4A 4B 4D 50 51 52 53 54 55 56 57 5A 60 61 62 63 80 90
   Z-Wave Debug                    . .  getInterfaceApiCapabilities: serialApi 3.07, manufactureId 0086, productType 0002, productId 0001
   Z-Wave                          connected to Z-Stick S2 interface on /dev/cu.usbserial-0001 (firmware 3.07, SDK unknown)
   Z-Wave Debug                    SENT forceSUC: 01 05 00 54 01 01 AE
   Z-Wave Debug                    RCVD forceSUC: 01 04 01 54 01 AF (no inbound callback)
   Z-Wave Debug                    SENT getInitialNodeData: 01 03 00 02 FE
   Z-Wave Debug                    RCVD getInitialNodeData: 01 25 01 02 05 08 1D 19 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 01 D8 (no inbound callback)
   Z-Wave Debug                    . .  getInitialNodeData: is static update controller
   Z-Wave Debug                    . .  getInitialNodeData: [1, 4, 5, 10, 12]
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 01 BB
   Z-Wave Debug                    RCVD getNodeProtocolInfo: 01 09 01 41 92 16 00 02 02 01 33 (no inbound callback)
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 001, class name: Static Computer Controller
   Z-Wave Debug                    . .  getNodeProtocolInfo:            class hierarchy: Static Controller : Static Controller : Static Computer Controller (02 : 02 : 01)
   Z-Wave Debug                    . .  getNodeProtocolInfo:         base class command: 00
   Z-Wave Debug                    . .  getNodeProtocolInfo:   supported class commands: 20
   Z-Wave Debug                    . .  getNodeProtocolInfo:     encrypt class commands:
   Z-Wave Debug                    . .  getNodeProtocolInfo:                   features: beaming
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 04 BE
   Z-Wave Debug                    RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 10 01 EC (no inbound callback)
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 004, class name: Relay Power Switch
   Z-Wave Debug                    . .  getNodeProtocolInfo:            class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01)
   Z-Wave Debug                    . .  getNodeProtocolInfo:         base class command: 25
   Z-Wave Debug                    . .  getNodeProtocolInfo:   supported class commands: 20 25 27
   Z-Wave Debug                    . .  getNodeProtocolInfo:                   features: routing, beaming
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 05 BF
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 005, class name: Relay Power Switch
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 0A B0
   Z-Wave Debug                    RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 11 01 EC (no inbound callback)
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 010, class name: Dimmable Power Switch
   Z-Wave Debug                    . .  getNodeProtocolInfo:            class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01)
   Z-Wave Debug                    . .  getNodeProtocolInfo:         base class command: 26
   Z-Wave Debug                    . .  getNodeProtocolInfo:   supported class commands: 20 26 27
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 0C B6
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 012, class name: Dimmable Power Switch
   Z-Wave Debug                    starting node healing thread
   Z-Wave Debug                    starting node status polling thread
   Z-Wave Debug                    SENT enterInclusionMode: 01 04 00 4A 81 30
   Z-Wave Debug                    RCVD enterInclusionMode: 06 (ACK)
   Z-Wave Debug                    RCVD inclusionMode ready: 01 07 00 4A 01 01 00 00 B2
   Z-Wave Debug                    RCVD inclusionMode node found: 01 07 00 4A 01 02 00 00 B1
   Z-Wave Debug                    RCVD inclusionMode adding slave node: 01 19 00 4A 01 03 0E 12 04 11 01 5E 26 85 59 86 72 55 5A 73 5B 9F 6C 70 22 7A 0A
   Z-Wave Debug                    RCVD inclusionMode node respondCmds: 5E 26 85 59 86 72 55 5A 73 5B 9F 6C 70 22 7A
   Z-Wave Debug                    RCVD inclusionMode node added: 01 07 00 4A 01 05 0E 00 B8
   Z-Wave Debug                    SENT exitInclusionMode: 01 04 00 4A 05 B4
   Z-Wave Debug                    RCVD exitInclusionMode: 06 (ACK)
   Z-Wave Debug                    RCVD inclusionMode finished: 01 07 00 4A 01 06 0E 00 BB
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 0E B4
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 014, class name: Dimmable Power Switch
   Z-Wave Debug                    . .  getNodeProtocolInfo:   supported class commands: 20 26 27 5E 85 59 86 72 55 5A 73 5B 9F 6C 70 22 7A
   Z-Wave                          controller included module: 014 - Dimmable Power Switch
Oct 16, 2022 at 3:19:49 PM
   Z-Wave                          Syncing - started for "014 - Dimmable Power Switch"
   Z-Wave Debug                    SENT getNodeNeighbors: 01 06 00 80 0E 01 01 77
   Z-Wave Debug                    RCVD getNodeNeighbors: 01 20 01 80 19 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 45 (no inbound callback)
   Z-Wave Debug                    . .  getNodeNeighbors: nodeId 014, neighbors: 1, 4, 5, 10
   Z-Wave                          Syncing - assigning return route to "014 - Dimmable Power Switch"
   Z-Wave Debug                    SENT assignReturnRoute: 01 05 00 46 0E 01 B3
   Z-Wave Debug                    RCVD assignReturnRoute: 01 05 00 46 01 00 BD
   Z-Wave Debug                    . .  assignReturnRoute: node 014, success 1
   Z-Wave Debug                    SENT requestNodeInfo: 01 06 00 60 0E 24 F3 40
   Z-Wave Debug                    RCVD nodeInfoFrame: 01 18 00 49 84 0E 12 04 11 01 5E 26 85 59 86 72 55 5A 73 5B 9F 6C 70 22 7A 8E
   Z-Wave Debug                    . .  nodeInfoFrame: node 014, combined class list: 20v1 26v1 27v1 5Ev1 85v1 59v1 86v1 72v1 55v1 5Av1 73v1 5Bv1 9Fv1 6Cv1 70v1 22v1 7Av1
   Z-Wave Debug                    SENT requestManufactureInfo: 01 09 00 13 0E 02 72 04 25 F4 4E
   Z-Wave Debug                    RCVD requestManufactureInfo: 01 05 00 13 F4 00 1D (node ACK)
   Z-Wave Debug                    RCVD requestManufactureInfo: 01 0E 00 04 00 0E 08 72 05 00 63 49 44 33 39 E0
   Z-Wave Debug                    . .  requestManufactureInfo: node 014, manufacturerId 0063, productId 49443339
   Z-Wave Debug                    . .  requestManufactureInfo: General Electric, Dimmable Power Switch
   Z-Wave                          Syncing - retrieved manufacture and model names: General Electric - 0063, Dimmable Power Switch - 49443339
   Z-Wave Debug                    SENT requestVersInfoGen: 01 09 00 13 0E 02 86 11 25 F5 AE
   Z-Wave Debug                    RCVD requestVersInfoGen: 01 05 00 13 F5 00 1C (node ACK)
   Z-Wave Debug                    RCVD requestVersInfoGen: 01 0F 00 04 00 0E 09 86 12 03 06 04 05 36 FF 00 AA
   Z-Wave Debug                    . .  requestVersInfoGen: node 014, protoVers 6.04, appVers 5.54
   Z-Wave                          Syncing - retrieved protocol version 6.04, app version 5.54
   Z-Wave Debug                    SENT requestVersInfoCmdClass: 01 0A 00 13 0E 03 86 13 26 25 F6 8B
   Z-Wave Debug                    RCVD requestVersInfoCmdClass: 01 05 00 13 F6 00 1F (node ACK)
   Z-Wave Debug                    RCVD requestVersInfoCmdClass: 01 0A 00 04 00 0E 04 86 14 26 04 4B
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 014, class command 26 using version 4
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 014, combined class list: 20v1 26v4 27v1 5Ev1 85v1 59v1 86v1 72v1 55v1 5Av1 73v1 5Bv1 9Fv1 6Cv1 70v1 22v1 7Av1
   Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01, base 26)
   Z-Wave                          Syncing - retrieved command classes: 20v1 26v4 27v1 5Ev1 85v1 59v1 86v1 72v1 55v1 5Av1 73v1 5Bv1 9Fv1 6Cv1 70v1 22v1 7Av1
   Z-Wave                          Syncing - retrieved encrypt commands: - none -
   Z-Wave                          Syncing - retrieved capabilities: routing, beaming
   Z-Wave Debug                    SENT requestAssociationGroupCount: 01 09 00 13 0E 02 85 05 25 F7 BB
   Z-Wave Debug                    RCVD requestAssociationGroupCount: 01 05 00 13 F7 00 1E (node ACK)
   Z-Wave Debug                    RCVD requestAssociationGroupCount: 01 09 00 04 00 0E 03 85 06 03 7F
   Z-Wave Debug                    . .  requestAssociationGroupCount: node 014, group count: 3
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 0E 03 85 02 01 25 F8 B0
   Z-Wave Debug                    RCVD requestAssociations: 01 05 00 13 F8 00 11 (node ACK)
   Z-Wave Debug                    RCVD requestAssociations: 01 0B 00 04 00 0E 05 85 03 01 05 00 79
   Z-Wave Debug                    . .  requestAssociations: node 014, group: 1, num associations: 0, max associations: 5, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 014, group: 1, associations: []
   Z-Wave                          Syncing - retrieved group 1 associations: []
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 0E 03 85 02 02 25 F9 B2
   Z-Wave Debug                    RCVD requestAssociations: 01 05 00 13 F9 00 10 (node ACK)
   Z-Wave Debug                    RCVD requestAssociations: 01 0B 00 04 00 0E 05 85 03 02 05 00 7A
   Z-Wave Debug                    . .  requestAssociations: node 014, group: 2, num associations: 0, max associations: 5, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 014, group: 2, associations: []
   Z-Wave                          Syncing - retrieved group 2 associations: []
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 0E 03 85 02 03 25 FA B0
   Z-Wave Debug                    RCVD requestAssociations: 01 05 00 13 FA 00 13 (node ACK)
   Z-Wave Debug                    RCVD requestAssociations: 01 0B 00 04 00 0E 05 85 03 03 05 00 7B
   Z-Wave Debug                    . .  requestAssociations: node 014, group: 3, num associations: 0, max associations: 5, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 014, group: 3, associations: []
   Z-Wave                          Syncing - retrieved group 3 associations: []
   Z-Wave Debug                    SENT addInterfaceAssociation: 01 0B 00 13 0E 04 85 01 01 01 25 FB B7
   Z-Wave Debug                    RCVD addInterfaceAssociation: 01 05 00 13 FB 00 12 (node ACK)
   Z-Wave                          Syncing - added group 1 association to interface
   Z-Wave Debug                    . .  addInterfaceAssociation: node 014, group: 1, associations: [1]
   Z-Wave                          Syncing - created device "014 - Dimmable Power Switch"
Users browsing this forum: No registered users and 37 guests
