Aeon ZWA011 issues
Tue Mar 15, 2022 4:40 pm
shapa offline
Aeon ZWA011 issues
Just received a bunch of ZWA011 - Aeotec Door / Window Sensor 7
ZWA011-C02
Syncs OK, not working properly (always "on" state).
It seems it's a new version based on 700 chipset.
https://www.vesternet.com/collections/z ... 700-series
The model is not recognised (it should be in the latest Indigo?), "Notification Sensor, firmware 2.00"
Z-Wave Syncing - started for "161 - Notification Sensor"
Z-Wave Syncing - assigning return route to "161 - Notification Sensor"
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0371, Notification Sensor - 0002000B
Z-Wave Syncing - retrieved protocol version 7.15, app version 2.00
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 80v1 84v2 85v1 86v1 87v1 8Ev1 55v1 59v1 5Av1 5Ev1 9Fv1 20v1 70v1 6Cv1 30v1 71v1 72v1 73v1 7Av1
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, waking
Z-Wave Syncing - retrieved wake interval of 10080 minutes
Z-Wave Syncing - device "161 - Notification Sensor" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved battery level of 100%
Wed Mar 16, 2022 12:40 pm
Re: Aeon ZWA011 issues
Indigo supports the ZWA011, but your version is reporting with a different model ID than Indigo currently has in its device definition. I've added the new ID to Indigo, so it will be in the next available release. In the mean time you can create a Trigger on the Z-Wave command using the Type Z-Wave Command Received, Event Incoming Command Received From Device, then select the Device and for Received choose Match Raw Packet and try the command byte sequence shown on this post.
Thu Mar 17, 2022 2:17 pm
shapa offline
Yes, RAW packet matching works.
